![]() Drives: Yaris 1.3 07 Join Date: Oct 2011
My Yaris accelerate too slow !!! any suggestions ??
I have 07 yaris sedan ... 1.3 A/T
previously ,, the top speed was about 180 km/h then i changed the wheels from 180/60/ R 15 to 195/50/ R 16 with HRS sport rims then i noticed that i couldn't accelerate to 180 km/h anymore !!? the car could hardly exceed 160 km/h !! ?? i did some modifications to improve the acceleration/top speed short ram intake (K&N) jasma cat back exhaust .. 2" inches tubes i feel some improvement ... but the top speed still sucks !! i'm still looking for faster acceleration and increasing the top speed a little bit !! Any suggestions ?? <<<< that's video showing the acceleration from 90:150 km/h http://www.youtube.com/watch?v=NAZLVNqzNy4 |
A wider exhaust tube will affect your top end, simply because you're losing back-pressure. Heavier/wider wheels will also affect your overall speed because of added rolling resistance.
At this point the only thing that comes to mind is to check your air filter and all related couplings. The filter should be as clean as possible, and the couplings should be very tight to make sure that there aren't any leaks adding to the problem. You might also want to consider getting rid of any dead weight (ie try to keep your trunk empty), which actually makes a substantial difference with our cars. Hope that helps!
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
my question is, how long was it between you doing 180km/h and your next try that only did 160? Did you have the other mods too at that time?
Like tk-421 said, wheels can affect rolling resistance, your exhaust and intake might actually increase mid-range torque a little, but reduce top end power, it's hard to be sure. I suggest you to check and clean your air filter. I let mine get real dirty over time, and it really sapped a lot of power, made a huge difference when I finally cleaned it up!
Wheels are probably taller and heavier. Making it accelerate slower and show a lower top speed on the speedo. I noticed a big difference switching from 17# 16's to 11# 15's as far as acceleration goes.
2ZR swap. DO IT! Ask how!
If you're into math/physics, here's a brief explanation of the laws that govern acceleration of rotating bodies: http://en.wikipedia.org/wiki/Moment_...ntum.2C_torque
This really boils down to an increased moment of inertia and a fixed energy source, so the angular velocity has to decrease to keep things in equilibrium. If you're not into the actual math, here's a brief summary: Going to a larger diameter wheel moves more of the mass away from the axis of rotation. Rotating a mass at a farther distance requires more energy to achieve the same acceleration/angular velocity. Try sitting in an office chair and spinning around while extending/retracting your arms. Now try it with your arms extended, then try with your arms extended holding some small weights. In the case of your wheels, you've gone to a larger diameter wheel (15" to 16") that is also likely wider than stock (5.5" to 6.5"). Your tire diameter didn't change significantly (1mm smaller) but you also added 10mm of width. Even if you kept the weight (mass) of the wheels and tires the same, you would still lose acceleration and top-end speed because you (in theory) haven't increased the power available from the engine. I know you tried a few things, but the energy required to compensate may be more than you can get from bolt-on parts. I discovered the same thing the hard way when I replaced my winter tires (175/70R14) with sticky summer tires (205/50R15). The only mathematical solution to counter this is to go with crazy lightweight tires to reduce the moment of inertia, but that's not financially do-able for me right now. |
#6 | ||||
it isn't related to the cleanness of the Airfilter because i did some tests while the filter was new - after purchasing it - .. and the same result !! Quote:
... btw: i did a test 2day with new stock airfilter - removed the k&N - and it only accelerate to 163 km/h |
You should disconnect your battery for an hour or two to reset the ECU to factory state every time you make changes. Remember that our ECUs are adaptive, so that could be an issue as well.
Your transmission could be slipping from heatin it up doing top speed runs. If you want to drive that fast you should get a m/t car. Or at least a big fat transmission cooler. Heat kills automatics.
Im pretty sure its the wheels though.
![]() ![]() Drives: 09 yaris hb Join Date: Jul 2010
hrmmm for me.... using the stock wheels and a gps speedo, at gps 110km/hr the speedo reads 113. using bigger wheels, speedo reads 106 at gps 110 . bigger tyres are 205/35/18. stock wheels are what ever comes standard on a Yr 1.3
and using the bigger wheels I couldn't get to the same high speed as the stock wheels on the same bit of road on the same night. I wasn't using the gps speedo tho also. IMO.. 2inch is 'big' exhuast for 1.3L usually for a 1.8 or 2L NA motor. But if it feels like a difference. it makes a difference :) hrmmm. do u have a cold air intake/pipe going to your airfilter? I"m not sure what comes with the short air ram kits. Maybe the radiator has more heat blowing over the air filter?? eh? |
#11 | ||
but i thought here's different case !! i mean that i used to accelerate to 180 km/h and nw i could not do that !! Quote:
then when you are about to upgrading the exhaust you should increase the tube 0.5 inches !! so it should be 1.75 inches !! ?? my intake is something like this http://www.youtube.com/watch?v=8wUXhlZWIfg |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 02:58 PM |
| Is a Yaris Really That Slow? | RacerFreakXXX | General Yaris / Vitz Discussion | 68 | 07-02-2010 04:01 AM |
