Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 08-06-2012, 06:36 AM   #2665
bongskitamtam
bongski
Drives: yaris homeboyz
@xtremist salamat sa information pre.
bongskitamtam is offline   Reply With Quote
Old 08-08-2012, 08:55 AM   #2666
bongskitamtam
bongski
Sir, wala bang effect sa makina natin ung pagpapakabit RACING FILTER?
Old 08-09-2012, 05:12 AM   #2667
syntax
syntax's Avatar
sir paki clarify po ung "racing filter" san po ito kinakabit? ito po ba ung aftermarket air intake filter?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
Old 08-09-2012, 07:06 PM   #2668
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
second demotion syntax musta na tagal mo ng naka hibernate a, hehe
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 08-10-2012, 08:12 PM   #2669
toyotaXa
Drives: toyota xa 2004 model
magandang araw po! gusto ko lang po sana humingi ng idea regarding sa windshield..,nagtanong tanong po kasi ako sa al khobar"sinaia" price ranges from sr260 to sr500..,made in china daw yung 260sr at finland naman daw yung 500sr.,both with warranty..,ok po ba ang quality ng mga windshield na yun?or anyone here na nakapagpakabit na ng ganoon klaseng windshield?..,
maraming salamat po!
toyotaXa is offline   Reply With Quote
Old 08-11-2012, 03:42 AM   #2670
bongskitamtam
bongski
@ syntax: opo sir un nga, air intake filter?
Old 08-11-2012, 09:29 AM   #2671
syntax
syntax's Avatar
oo nga pre' hibernate muna ako, dami problema eh, kapag nakabawi bawi na lang
Old 08-11-2012, 09:33 AM   #2672
syntax
syntax's Avatar
ang epekto ay mas marami at mas mabilis ang paghigop ng hangin that equals to mas mabilis na arangkada ( short ram intake or SRI) or mas mabilis na top end speed (rektahan kapag Cold Air Intake or CAI) ang drawback ay dapat lagi mo nililinis ang air filter mo at throttle body...other than that wala na ako maisip na magiging epekto sa makina, at hindi rin ito guaranteed na may dagdag na HP kung ito lang ang ilalagay na aftermarket parts
Old 08-11-2012, 07:00 PM   #2673
duke_afterdeath
Old 08-12-2012, 03:35 AM   #2674
kaemong
Drives: yaris 2008
Originally Posted by kaemong View Post
mga sir, konting katanungan at tulong...
ang yaris ko kasi buhat nung pinalinis ko yong throttle, lumabas na yong Malfunction Indicator lamp. Ok naman ang takbo nya walang problema sa hatak. naaburido lang talaga ako sa ilaw na yon. tapos last week, tiningnan ko yong pagkahigpit ung malapit sa throttle eh maluwang siya, so hinigpitan ko baka may singaw lang...pero ganun pa rin, di pa rin nawawala ung ilaw, 1 month na cguro na ganun. saan kaya pwedi ipaayos yon, yong di masyadong mabigat sa bulsa kasi wala pa budget...nakaka-aborido lang na may makita ako ilaw...salamat sa suggestion...
pina computer scan ko na yaris ko para makita kung ano problema nya. lumabas na ung sensor dun both sides sa may block (di ko alam kung ano name nun - binabalance daw nun ang timing) tinanung kung ung kabayan kung magkano abutin pag ipagawa ko, kulang-kulang 500 SAR daw. waaaaaaaa...canvas muna baka may mabilhan pa na mas mura.
btw. pinagawa ko na rin pala kagabi ung water pump ko na maingay, parang sirang bearing, bumili ako ng bago (195 SAR) nawala na ung malakas na ingay pero may naririnig pa rin ako from air compressor naman. suspect ko may tama ung pinalit na air compressor. may nagrerepair ba ng air compressor bearing?
kaemong is offline   Reply With Quote
Old 08-12-2012, 04:59 AM   #2675
bongskitamtam
bongski
@ kaemong: Sir nasubukan nyo po bang ibalik ung stock nyo na filter para malaman nyo kung may iilaw pa din?
Old 08-14-2012, 09:59 AM   #2676
kaemong
Drives: yaris 2008
ok na sir, sa wakas natanggal din ung malfunction indicator, nagpalit ako ng vvt (140 SAR + 60 labor). ang problema ko na lang ngayon ung tunog na nanggagaling sa air compressor.
Old 08-22-2012, 06:15 PM   #2677
macky
Drives: yaris
mga bro. paano ba mag palit head light bulb . dito kasi maabot masikip
macky is offline   Reply With Quote
Old 08-23-2012, 03:24 AM   #2678
syntax
syntax's Avatar
@ duke pasooookkkkkk
Old 08-23-2012, 10:55 AM   #2679
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
@macky, if that's the case kailangan mong tanggalin yung buong headlight(housing) para mas komportable kang maalis ang headlight bulb, pero normally nadudukot yan ng iba.
jonimac is offline   Reply With Quote
Old 08-25-2012, 01:15 PM   #2680
duke_afterdeath
bakit masikip? head light bulb yata ang pinakamadaling palitan sa lahat ng bulb, hehe.. pagnahugot mo na ung rubber sealed cap angat mo lang ang clip ng bulb matatanggal na kusa un
Old 08-26-2012, 02:57 AM   #2681
bongskitamtam
bongski
Mga pre konting katanungan lang about dun sa CAI nagtanung kase ako sa ghurabi nung pipe kay (Ford) kaya lng may sinasabi pa sila na may kailangan pa daw i modify para sa lagayan nung sensor parang magdadagdag ng elbow daw, panu n san ba idudugtong yun?
thanks..
Old 08-26-2012, 06:56 AM   #2682
jonimac
jonimac's Avatar
thanks..
@bongskitamtam, eto yung nilalagyan ng MAF sensor. Dati kasi pinuputol namin yung STOCK, makuha lang yung mounting ng MAF, pero ngayon may nabibili ng ready made. Pumunta ka sa AL AQSA may kabayan dun ROY ang pangalan, nandun din sa kanila yung mga tube extenders kung gusto mo ng CAI. Location? ....going out from Jolibee st., intersection yun diba? Pag kaliwa mo nasa kanan mo kagad yun AL AQSA na, daming anik-anik sa oto dun. enjoy!
