Old 08-29-2012, 12:35 AM   #1
detroiter
detroiter's Avatar
Stock struts...go back to factory height or keep lowered?
Well my Tokicos have a ton of mileage on them, probably close to a good 80-95,000 miles on them and I figure it's about time to replace them. The suspension is getting really hard on bumps and bouncy otherwise. My thing is I have the stock shocks that I could put back on that are maybe about 30,000 or so easy going miles on them. The question is, do I pair them up with the Tein springs I'm currently on or should I just go back to factory springs with them?
Old 08-29-2012, 07:57 AM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Do you notice any physical damage to the tokicos? Are they leaking? When you push down on the car does it compress down and not rebound? Just trying to help you avoid replacing them if possible.
Old 08-29-2012, 08:25 AM   #3
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
I'm running stock shocks with approx 95k on them with the MI springs, and I've had no issues so far. I am, however, looking to replace them ASAP as there is quite a bit of squeaking when I push the car into corners or over bumps.
That being said, if you only have 30k on yours, you'll be good for awhile, especially if you plan to replace or rebuild the Tokicos.
Old 02-14-2013, 04:55 PM   #4
SKurj
Drives: 09 Yaris 3dr HB, BRZ
Well depending on how much its lowered... you could blow the stock shocks and struts if you use them with the springs. If its only around 1" drop you would be ok.
I have tokico blues with tein springs, around 70,000kms on them now and they work like the day I got them. Of course in the winter they are firmer until they get a chance to warm up abit.
SKurj is offline   Reply With Quote
MI springs back in stock! cali yaris Micro Image 14 06-30-2012 03:17 PM
any rubbing issues with stock height and... severous01 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 03-15-2010 01:22 PM
can someone measure stock ride height? thebarber Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 07-29-2009 02:02 PM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 05:59 PM
stock ride height or spring sag? mikeukrainetz General Yaris / Vitz Discussion 5 12-21-2006 01:00 PM
