![]() Drives: Toyota Yaris SR 2008 Join Date: Aug 2012
2008 5 door Yaris 1.3 TR rear hub replacement.
Hi,
I have a 2008 5 door Yaris 1.3 TR hatchback with 42, 000 miles on the clock. I have recently noticed a droning noise which seems to be coming from the o/s/r of the car, I jacked up the car and spun the wheels and the offside rear feels rough compared to the others so I suspect it is this wheel bearing that is on the way out. There is a wire attached to the hub which I guess is the ABS connection. From what I can gather you replace the hub assembly rather than just the bearing, is this correct ?. Has anyone done one these ? It looks like it's held to the rear suspension with 4 bolts so wonder if it is a straight forward job ?. I have seen a few of these hub assemblies on E bay at various prices. Thank you in advance for any help. All the best John |
The rear hub is relatively easy to change. You just need to located one that is ABS equipped as well:
Hi,
Many thanks for your reply and for the diagram. Yes it doesn't' look too difficult, I will locate a hub with ABS and have a go. Thanks again John |
#4 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
That is interesting that such a crazy expensive part is considered non-reusable. I have no idea as to why Toyota did that, unless the part gets damaged in the process of removing it from the hub.
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| New 2008 LB with Front and Rear skirt! | GabL | Canada | 7 | 10-01-2007 02:29 PM |
