![]() ![]() ![]() Drives: 2012 toyota yaris Join Date: Jan 2012
ebay foglight kits
i see there are many shops/vendors on ebay selling aftermarket 2012 yaris foglights for the L and LE models. Has anyone bought a set of these yet? i was continplating on getting a set. i do realize when you buy ebay parts, you get ebay quality but you can't go wrong for under a $100 bucks.
here's a link to one set i seen on there . http://www.ebay.com/itm/12-13-TOYOTA...#ht_4159wt_991
2012 yaris L model 2014 wrangler unlimited sport |
Where's my crown?
Drives: 07 self proclaimed TRD Sedan Join Date: Sep 2012
I've got the yellow k2 set on the way...fingers crossed its not a cluster bomb of fuckin dismay
I am the obvious resolve to the age old question, "What happens when an unstoppable force meets an immovable object?"
#3 | |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
On my 2012 L, I did not need the included harness, nor the relay or switch. The car was prewired, I installed the lamps, and covers, then wired 2 wires of a 4 wire switch to jump the purple and green wires of the stalk connector at the bottom of the picture. The other 2 wires were tied to the shifter illumination wires. Credit to CTScott
Cheapest DD I could find!! |
#4 | |
#5 | |
Asshole
Pulled the pins on the upper bumper, pulled out both sides from the fender. Bumper leaned forward, and I reached down to install the lights. Found the fog plugs taped to a harness, right next to where the fogs are. Did not remove anything from the bottom of the bumper. The only reason I pulled the bumper was that I replaced the headlight bulbs with Philips CrystalVision Ultra 9003 Headlight bulbs, to match the same H11 I replaced in the fogs. These fogs only come with Osram 3000K bulbs.
im still researching. im very tempted in buying a set of these ebay fogs.
#7 | |
Asshole
$99 http://www.amazon.com/Lights-Lamps-T...ords=yaris+fog
how long did it take you to install? and these were dot approved?
also do they have them with the yellow lenses?
#9 | |
Asshole
Didnt see yellow, just use these: http://www.amazon.com/Nokya-H11-Yell...keywords=nokya Bumper side, 15 minutes including new headlight bulbs. Inside, 20 minutes, removed the lower steering wheel shroud, ran 2 wires from the switch I installed on the left dash cutouts. Tapped into the 2 wires as above.
#10 | |
#11 | |
Asshole
One of the fog lamp ears slides into slot in bumper, and they give you 1 screw for the other side. Add a screw to the ear below the slot for added safety.
i went ahead and placed a bid on a set of yellow lens ebay fogs for my 2012 3 door. im looking forward to getting these badboys!
#13 | |
Asshole
I think you should have got the clear, and then you could change bulbs as needed.
i wont the auction last night, as of today i made payment of $95.99 free shipping. thats not too bad for some fogs. hopefully they should come soon and i'll get started with them
![]() Drives: Yaris 2012 Join Date: Oct 2012
Just installed mine yesterday and it works really well. Took me about 1 hour in total. It fits and works just like OEM.
#16 | |
![]() Drives: Yaris & Corolla Join Date: Aug 2012
Is there a trick to it, or do you simply pull it out as you said? I'm OK with the pins on the upper bumper, so I'm halfway there! Cheers in advance! |
#17 | |
Asshole
It will remind you of a hood (bonnet) being opened on a Mack truck!!
#18 | |
![]() Drives: NCP131 Join Date: May 2012
| FEELER: Possible New HID Vendor | hydrohopper | Cosmetic Modifications (Exterior/Interior) | 17 | 06-11-2010 02:05 AM |
| WTB: Gauge Cluster w/tach for HB | cdydjded | Willing to Buy by private party | 12 | 06-09-2010 04:49 PM |
| Pre Hack Revival: Megan Racing Header vs Ebay Header | Sabretooth | Performance Modifications | 15 | 08-19-2009 06:26 PM |
| Toyota Yaris 5 Doors Body Kits | k3nn4 | Australia | 23 | 05-08-2009 11:28 PM |
| 2009 foglight kits? | songa | Cosmetic Modifications (Exterior/Interior) | 3 | 12-10-2008 12:58 PM |
