Old 10-17-2012, 12:33 PM   #1
Joshua1902
Drives: Yaris tsport
Do I need to remap?
Hi, I'm looking at putting a 4-2-1 manifold and a full stainless straight through which has a decat, do I need to remap my car after this or will it be fine to run?
Joshua1902 is offline   Reply With Quote
Old 10-17-2012, 12:41 PM   #2
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
You'll just need to reset your ECU. Remove the neg battery terminal for 5-10 minutes, then replace, and the ECU will re-learn the fuel trims to level off your idle (about 5-10 minutes as well). It may take up to a day or two to really level off as it finishes the fine tuning.
Old 10-17-2012, 12:44 PM   #3
Joshua1902
Do I need the engine started when I remove the negative terminal, is this the only thing I will need to do?
Old 10-17-2012, 01:03 PM   #4
suckerface
#1 Lemming
suckerface's Avatar
No, engine off, remove neg terminal, install header, replace neg terminal, start car. No idea what sort of havoc you would create removing the neg terminal when the car is on.
Old 10-17-2012, 01:28 PM   #5
Joshua1902
Thanks, ill let the garage know before they swap them over
