![]() ![]() ![]() Drives: Gray Join Date: Jun 2012
Light Rust or Grime on Brake Pads ?
Hi, my 2012 Yaris is roughly (3) months old, I recently noticed on the front brake pads, especially between the brake pads, what appears to be rust. The front brake pads have it too, because I could reach the front pads, I was able to wipe it off with a paper towel. How do I clean the rust that is visible between the two front brake pads, my solution is to blast it with water ?
What ?!?!?
It's not cause I have to park outside is it ? I want to clean the brakes, so I don't see that, for a new car, arghh.
Still don't understand what you are talking about.
Is it rust on the rotors that you are referring to? If it is, then the answer is live with it. It happens when a car sits in a moist environment. They can begin to rust in a matter or hours. Clean right up again as soon as the car is moving and the brakes get applied. If you are not referring to your rotors, then try to clarify more. Pictures would help.
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
LIke WeeYari said, if you're talking about the rotors, either deal with it, or brake harder. That'll burn off the rust.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
DAT'S RIGHT I GOTz 2
and like magic it reappear the next day
#7 | |
#8 | |
If you've got a chronic amount of rust that doesn't go away, it either indicates you're not using the brakes enough to burn off the rust, or there's an issue with the brake itself, causing one or both pads to not contact the rotor. Since it's a 2012, it's very unlikely that there's any issue with the brakes. Brake a little harder and the rust will get worn off. A paper towel won't get the rust off that's on the part of the rotor that's inbetween the pads, and it also won't clean off the rust that's on the pads themselves. A lot of people are scared to drive their cars "hard", but the engine and brakes benefit from it every so often. Finally, an additional commentary, a lot of "lightly driven" cars that have rear disc brakes have issues with the rear brakes seizing up due to a lack of heat, which never ends up burning off condensation and rust from the various brake components.
![]() ![]() Drives: Yaris Sedan Join Date: Apr 2012
If you are talking about the brake surface, where the pad touches the disc, it should go away with driving. If it's really bad and can't go away, you might consider resurfacing the rotors.
However, I think you may have meant this... if you are talking about the rotor where the pads doesn't necessarily touch, like the hub or outer diameter of the disc, you may paint it to prevent corrosion. The corrosion won't hurt you, just aesthetics. |
If it comes off with a simple wipe of a paper towel it might just be brake dust.
![]() ![]() Drives: 07 Toyota Yaris Hatch-Back Join Date: Jul 2010
It's most likely the moist in the air at night that causes ur rotors to be rusty...if u see rust here and there or spotted rust...then u should be fine, while u drive during the day it'll burn right off...it happens to me all the times especially when I wash my car....but as soon as I took it a drive the rust will go away
Can you post a picture?
My immediate reaction is there is nothing to worry about. You have a tempest in a teapot here.
i would do what bronsin had said...take a few pictures of how it looks and post it on...but like we all say here...there's nothing u should be worry bout...
#14 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
It's nothing to worry about, your rotors are bare metal and a little surface rust will happen when they get wet. In extreme conditions, your brakes can even "lock up" a little requiring a bit of forward movement to break free (this used to happen to my Passat in Belgium). But for the most part, they will clear up as soon as you use your brakes.
I travel a lot for work and if we get any rain while I am gone, my brakes usually are covered in surface rust when I get back. I just returned from being gone a week, and this is what mine look like... ![]() It's nothing to worry about, it'll clear after a mile or so of driving and there is no advantage to trying to clean it off beforehand... Cheers! M2
#15 | |
#16 | |
Every car with disc brakes has rust like this. Dont be concerned.
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 09:50 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| one brake light out | xartrax | DIY / Maintenance / Service | 3 | 01-27-2011 01:40 PM |
| New brake pads and noise | eii | DIY / Maintenance / Service | 8 | 06-25-2009 11:49 AM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 05:43 PM |
