#73 |
![]() Drives: Charcoal '08 sedan Join Date: Sep 2011
Actually you were right. The constant 12v works there so I hooked in the violets and the red there and the dealer suggested it might be the ground so I put all three of those together on the ground. Still only locks and doesn't unlock or vice-versa. So close.
Does it matter that the ground isn't a ring? I got one of those U-shaped connectors. I can buy a ring if need be but I didn't think it was a big deal. Otherwise I'm just cruising forums looking for someone with the same problem. Should I try using the violet wires or the brown/black and white black as the lock/unlock wires instead? That doesn't really make sense but the manual says polarity could be the problem so... I'm lost. |
#74 | |
A ring terminal doesn't matter as long as you are on a solid ground (for example the bolt under the driver's kick panel). With the actuators, are they two wire? If so, Blue/Black should go to one of the two wires and Green/Black to the other.
#75 |
Yeah, sorry for not being clear. I wrapped black, black/white, and brown/black and put them into a u-shaped connector and then connected it to the ground bolt.
I'm thinking if maybe somehow there's not a good connection with the pink ignition cable, maybe the remote is programmed incorrectly. I'll figure something out hopefully. And yeah, they are two wire actuators. |
#76 | |
Disconnect the blue/black and green black wires from the actuators and measure the voltage between them. It should be 0V with no button pressed and the +12 when one button (lock/unlock) is pressed and -12 when the other lock/unlock is pressed.
#77 |
Free Mustache Rides
how many parts are used in the coilibri kit? im finding all sorts of kits places, but none that have as many washers and brackets as that kit. how many are actually needed?
#78 |
Hey, good news! I got everything up and working. Turns out the tap splice to the ignition wire wasn't a good connection so while I had thought I had programmed it, I obviously hadn't. So once I got that programmed it now locks and unlocks. Hooray.
Time to tape everything up and put it back together. Now to name my first child CT or Scott, kidding... |
#79 | |
The yaris has cable-pull locks so you need special brackets to hold the cable sheath stationary while the actuator moves the cable (see the first post). That's what all the parts are for. Good luck. |
#80 |
![]() ![]() ![]() Drives: Flint Mica Sedan Join Date: Oct 2008
Bought this kit and it came today. Took me four hours to do the first door, lol. Do the doors not lock or unlock after you have the kit completely assembled and tightened down? I only have the rear left door done, and the lock doesn't move when trying to do it manually.
#81 |
Well I got all my actuators, etc working. My question is. Where did you connect the red power wire to? The battery or is there somewhere under the dash I can connect it?
#82 |
Basically I can't figure out which open spot in the fuse box, under the dash to use to get the constant 12v of power.....???
#83 |
Check out my remote start DIY for a good location for a high current constant +12:
http://www.yarisworld.com/forums/showthread.php?t=24860
#84 |
hell might as well fatmat that door for a quieter ride ;P
#85 |
Well I finally finished installing the power locks and keyless entry. So far so good. Just hoping the lock cable doesn't snap anytime soon.
#86 |
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
How much more difficult is it to install the security system if I ordered the package from A1electric with it?
http://www.a1electric.com/Merchant2/...Code=W01F-740T |
#87 | |
#88 | |
At the same time, am I biting off more than I can chew?
#89 | |
#90 |
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 02:59 AM |
| Need Help - Electrical (finding Power) | Ayka | DIY / Maintenance / Service | 7 | 10-12-2006 11:51 AM |
| The power upgrade thread | ChinoCharles | DIY / Maintenance / Service | 19 | 09-27-2006 03:14 PM |
