Hey guys, long time no post. I am going to replace the shocks and struts on my '07 Sedan. Just had a couple of questions before I tear into it.
Do I access the rear shock upper mounts from inside the car or through the trunk? Its kinda of hard to tell from the outside. Do I need to remove the cowl to get to the upper mounts for the struts? I have read some do and some don't. Lastly and I am sure I know the answer but is it necessary to have an alignment done after replacing the struts? Or can I just take note of the mounting of the original. I am replacing them with Monroe struts. TIA
I am not allowed to put anything here because I do not have any ricey mods on my Yaris.... |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
So, having a hatch, this may not be accurate, but I'm guessing the rears will be accessed through the top, and the fronts, I had to remove the cowl (you get used to it after doing it 3 or 4 times ;) )
As far as alignment goes, give it a hundred miles or so to break in, then have one done. Good luck!
#3 | |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
A long 6MM allen wrench, with the short end ground down to 1/2" long. A 17MM deep offset box wrench will both sneak under the cowl to loosen. Then you can reach your hand in and remove the nut. I highly recommend spending a few $$ and getting the Tokico Blues.
Cheapest DD I could find!! |
#4 | |
![]() ![]() ![]() Drives: Toyota Belta Join Date: May 2011
Thanks for the responses so far guys. I already bought the struts and got them really cheap. I cant really afford to spend any more.
Still looking to confirm where to access the top mounts for the rear shocks on a sedan.
Unlike the HB which has nice popout access panels to access the shock, I believe the sedan requires removal of the entire side panel in the trunk. A friend with a sedan bitched about how easy the HB guys have it when it comes to rear shock removal.
Thanks WeeYari!
Mr. 155 and climbing
yup...that is the case for the rears in the sedan. also, why not remove the cowl? it is easy. I have done it prolly literally 100+ times now. 14mm for the wiper arms and a 10mm for the 8-10 black bolts. You have to remove the wiper motor first before the metal cowl plate and don't forget the wiper fluid hose like I always do upon reinstall! haha.
Asshole
Because, its not needed!!
| test driving 07 yaris on Sun, quick questions | rickc | New YARIS Purchase Forum | 17 | 08-29-2012 06:25 PM |
| Shock and Struts Replacement... New Tires | Blowtorch | DIY / Maintenance / Service | 3 | 07-25-2012 01:44 PM |
| Yaris Questions | Tokiko | New YARIS Purchase Forum | 21 | 07-31-2007 08:36 PM |
| Questions, questions... | littlecarlove | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 10-21-2006 02:42 PM |
