Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 07-01-2012, 01:55 PM   #37
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Like the 2nd pic ...Pwede na sa PYLOX yan, mura lang yun tol!
@charlie, sponsor ka dyan...IKAW pa?!hehehe
jonimac is offline   Reply With Quote
Old 07-02-2012, 05:02 AM   #38
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
how much pylox tol joni? ano, tirahin natin sa friday after natin magpakabit ng bore centric ring ni minnie?
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 07-03-2012, 05:01 AM   #39
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Tol FINK bagay din he he he
Originally Posted by duke_afterdeath View Post
tol sakin din may nag sponsor hahaha.. Attachment 47510Attachment 47511ano kaya mas magandang kulay color wheels for a change
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 07-04-2012, 08:28 AM   #40
Marlboro
Marlboro's Avatar
Drives: Yaris
querries
tol joni ask lang naka lowered ka di ba? ala bang sayad ang 17" na rim? ganu kalapad yung gulong? 6.5 or 7?
Marlboro is offline   Reply With Quote
Old 07-04-2012, 09:39 AM   #41
jonimac
jonimac's Avatar
@marlboro, 17x7 @ +40 offset yung rim. Yup! Poor-mans lowering spring lang po, so far wala namang rubbing issues kahit full load ako bro.
Old 07-07-2012, 08:55 AM   #42
Marlboro
Marlboro's Avatar
Drives: Yaris
rak en rol ayos yan kung alang rubbing issue hehehe ayois gwapo na oto mo.
Old 07-15-2012, 08:48 AM   #43
charlieXX
Corporate Slave
charlieXX's Avatar
Tol yung driver dati ng fogeee he he he
Old 07-15-2012, 08:48 AM   #44
charlieXX
Corporate Slave
charlieXX's Avatar
Calling calling Marlboro nawala ka na sa circulation ah
Old 08-11-2012, 06:31 PM   #45
johnraiden12
Drives: toyota yaris sedan 2007
mas gumanda ang takbo ng yaris ko ng palitan ko ng 205/50/16 un lang ang masasabi ko pro try ko prin palitan ng 205/45/ after .
johnraiden12 is offline   Reply With Quote
Old 11-23-2012, 04:12 AM   #46
blackmamba
CP3
blackmamba's Avatar
Drives: BM - Yaris 2012 Sedan
@boy, some factors are to be checked, isa na rito yung OFFSET ng rim mo kaya medyo naka labas at na-sayad sa fender. May mga naka setup sa grupo na 205/50/16 pero walang sayad o anuman. Most of them 205/45/16 ang nakalagay at lalong walang problema. Meron pa ngang naka 205/45/R17 wala ring sayad na nabanggit sa amin. If you don't mind kindly check first the offsets of your rims, it should not be less than 38, going below this lalabas ang gulong mo. Minsan din nakaka apekto ang design ng rim, may pasok o labas ang mga LUGNUTS, you will notice nagbabago mga OFFSETS ng rim depende sa mounting nila. Otherwise, go for smaller rims katulad ng nabanggit ni syntax 15" to be safe at all. It's up to you bro, "LOOKS" or COMFORT". Kasi ako balak kong mag 18" (215/35/R18) ....joke! In my dreams!!!
Kung 205/50/16 wala ba namang sayad kahit loaded yarii natin?
blackmamba is offline   Reply With Quote
Old 11-25-2012, 01:45 AM   #47
syntax
syntax's Avatar
@ blackmamba depende pa rin sa offset ng rims...
Old 11-25-2012, 03:16 AM   #48
blackmamba
CP3
blackmamba's Avatar
ano recommended na offset ng rims para walang rubbing issue?
Old 11-25-2012, 07:22 AM   #49
syntax
syntax's Avatar
pre as per jonimac from his previous post.. dapat not less than +38 ang offset ng rim para walang rubbing
Old 11-25-2012, 08:38 AM   #50
blackmamba
CP3
blackmamba's Avatar
thanks for the info bro.
Hankook Ventus HR II 205/40/16 dngz Items for Sale by private party 0 10-06-2006 01:24 AM
