Old 11-25-2012, 06:20 PM   #1
Machinist
Drives: Blue 2dr. LB
Powering rearview mirror.
Just wondering if anyone could tell me where a good source is for wiring up a rearview mirror with self-dim, compass and temp. All I need is a 12 volt pos. source and a 12 volt pos. switched source. I see a lot of info. for wiring up a remote start and/or alarm just not sure if I should use the same info. or not? Thanks in advance for any help.
Machinist is offline   Reply With Quote
Old 11-25-2012, 06:53 PM   #2
The locations in my remote start DIY are probably your best bet as well for the mirror. That way you come across the front of the headliner, down the A Pillar and right to the under dash fuse panel.
Old 11-25-2012, 07:22 PM   #3
Machinist
Thanks for the reply CTScott. I'm looking at your remote start wiring guide pdf and curious as to which ignition wire is better to tap into for a switched output, ignition #1(green) or ignition #2(pink)? Thanks again for your assistance. Also I take it I don't really need to consider the accessory(white) wire, correct?
Old 11-25-2012, 08:00 PM   #4
For IG switched, I prefer the pink wire. Correct that you don't need the accessory one, unless you want to have it powered with the key in the ACC position.
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 03:16 AM
Rearview Mirror with map lights Yari213 Cosmetic Modifications (Exterior/Interior) 5 08-06-2011 08:18 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 12:48 PM
Replacing Rearview Mirror for Smaller One molinee Cosmetic Modifications (Exterior/Interior) 7 11-06-2008 11:56 PM
Rearview Mirror Too Big? molinee General Yaris / Vitz Discussion 23 11-06-2008 04:17 PM
