Old 11-18-2012, 03:45 PM   #1
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
Transmission fluid level
Hello. I am having problems reading my transmission fluid dipstick. Sounds stupid, I know. So the problem is, the fluid level doesn't cover the entire stick. Like it has fluid scattered all over the stick so it's not readable. I had Toyota change the fluid and I'm not sure if its so low to the point that its not readable or if I'm doing something wrong. How should the levels look on a normal reading of the dipstick?
Twistoffate0817 is offline   Reply With Quote
Old 11-18-2012, 06:28 PM   #2
Wipe it, stick it back in, pull it back out, and then read it.
Old 11-28-2012, 05:15 PM   #3
Twistoffate0817
I added 1/2 a quart, and then had Toyota look at it and the level was just at the bottom of the notch that said hot. I am guessing that is good enough in terms of enough fluid being in there.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 05:18 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Inception (movie) Kioshi Off-topic / Other Cars / Everything else Discussions 25 08-10-2010 02:08 AM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 06:51 PM
