Old 11-28-2012, 10:40 PM   #19
Originally Posted by DJYojimbo View Post
How many ft lbs is it supposed to be?
There isn't a torque measurement for a belt, but rather a deflection and a tension measurement. They point to check is half way between the alternator and the crank pulley.
Deflection:
New belt 7.0 to 8.5 mm (0.28 to 0.33 in)
Used belt 11 to 13 mm (0.43 to 0.51 in)
Tension:
New belt 539 to 637 N (55 to 65 kg, 121 to 143 ld)
Used belt 245 to 392 N (25 to 40 kg, 55 to 88 ld)
Old 11-28-2012, 10:42 PM   #20
frownonfun
frownonfun's Avatar
when i had a loose belt it sounded like there was a pig being slaughtered under my hood. so idk, that doesn't sound so much like a loose belt to me. then again if CT says it does maybe you should listen to him.
I crush you like tiny clown car, because you are clown, yes?
Old 11-28-2012, 10:47 PM   #21
frownonfun
frownonfun's Avatar
Deflection:
Tension:
Yeah it's funny I called my service dept to ask them if they can measure the deflection for me and they said there's no way to measure it. They also said that because there's no tensioner that I wouldn't need to worry, it will tighten itself. I seriously wonder if I should be letting these people do my oil changes, even if it is free.
Old 11-29-2012, 10:46 AM   #22
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
I assume you have already checked to make sure that the belt isn't bottoming out in the groves on the pulleys, that there is not any debris in the pulley groves, and that the pulleys are aligned?
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 11-29-2012, 01:36 PM   #23
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
nope. haven't popped the hood at all. been too busy and it's cold.
figured I'd ask if this was normal before I started poking around. I used to be under a car 5 days a week swapping trannys, replacing front ends, etc... but these days I am not a big fan of doing work myself anymore, lol.
Captain Slow is offline   Reply With Quote
Old 02-03-2013, 01:59 PM   #24
Captain Slow
hey guys, sorry it took me so long to reply to this topic, I've just been busy.
here is a wav file of the sound, about halfway through the idle drops and you can hear it even better. keep in mind that this was taken with the hood closed standing next to the car, not with the recorder in the engine bay.
think it may be time for a new belt or at least a retension on this one? It doesn't do it when I first crank up in the morning but starts 2-3 minutes later (I'm guessing as the belt heats up it expands).
Does the Yaris have automatic tensioners or is it something adjustable? Thanks.
FILE
http://www.filedropper.com/beltnoise
Old 02-03-2013, 03:49 PM   #25
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
i had a bad squeal initially. new belt fixed that. now...after about 10,000miles or so...it does a tiny squeak on start up. I looked at the belt, its looks worse then it should for its age. im going to tighten it up a tiny bit more the next time i get a chance.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 02-13-2013, 07:47 AM   #26
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
I've been having this same noise. It only happens when I drive the car for a while, and it doesn't happen when you first start the car up.
Black_griffin6 is offline   Reply With Quote
Old 02-13-2013, 08:21 AM   #27
Captain Slow
^exactly, and it's annoying as hell.
Old 02-15-2013, 07:26 PM   #28
Captain Slow
Just listen to the wav file I attached in an earlier post.
Old 02-15-2013, 08:53 PM   #29
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
the file in the earlier post is not normal. the filedropper link just goes to the main page, not to a file i can use.
i'd agree with CTScott. I have a full nst pulley set, and after tightening all the belts, i have zero extra noise that sounds anything like that. There is a chance the belt might be too tight as well, but that is a belt noise of some type.
Colin Chapman disciple
Old 03-25-2013, 06:00 PM   #30
DJYojimbo
Drives: 2012 Grey Toyota Yaris SE
still having issues with the pulley?
DJYojimbo is offline   Reply With Quote
Old 07-31-2013, 02:00 PM   #31
catliektheif
catliektheif's Avatar
Drives: 2010 5 Door
@captainslow I'm having the same exact noise after the MI pulley and its driving me INSANE. Did you find a fix?
lol okay
Old 07-31-2013, 02:11 PM   #32
yougojay
25, 550 MILES!
Drives: Yaris L Coupe
Originally Posted by tooter View Post
My wife says I have selective hearing.
What...?
yougojay is offline   Reply With Quote
pulling the AC belt pulley on front of compressor yaris9876 DIY / Maintenance / Service 6 07-19-2012 10:12 PM
Squeaky belt after pulley install? Black_griffin6 DIY / Maintenance / Service 12 07-01-2012 10:17 AM
Belt noise? Cutie Pie #2 DIY / Maintenance / Service 20 05-22-2009 01:51 PM
Water pump belt and pulley - replaced at 36,000mi cleong DIY / Maintenance / Service 3 03-06-2009 12:12 AM
Underdrive Pulley Belt ruimond Performance Modifications 11 02-14-2009 09:05 AM
