Old 11-28-2012, 02:16 AM   #1
yariseggvvti
Drives: Yaris Hatchieback
battery light on and off
I got my alternator replace and the battery light on and off. Battery with 100% good. The vehicle running find but the light is on and off. when the light is on kinda blinking dim. Any idea??? Thanks!!
2007 hatch with 72k now. What else I need to check. Ground cable is good.
Autozone alternator is good enough I think. I am going to order one from Toyota. I am going to install it this weekend. Hopefully the solve the problem.
yariseggvvti is offline   Reply With Quote
Old 11-28-2012, 06:16 AM   #2
That seems to be a common problem with aftermarket alternators. They don't seem to properly output the signal to the cluster. Have you measured the voltage with the engine running to see what the actual output of the alternator is?
Old 11-28-2012, 01:25 PM   #3
Geoff Peace
Drives: Yaris 1.33 litre 2011
This happens here in the UK with some aftermarket alternators not only on Toyota but other makes as well. If bought from a reputable supplier, usually OK but there seem to be a lot of cheap rebuilds which are not OK. I think the quality of the components used is not up to the mark, particularly the rectifier and regulator. Just one leaking diode will create the problem you describe.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 11-29-2012, 01:20 AM   #4
yariseggvvti
Thanks for you time CTScott and Geoff Peace.
your information helps a bit. I am going to replace OEM Toyota alternator. I hate the light come on the off. It makes me feel annoying. Lucky I purchase the alternator with 28% off the list price. Dont trust any none OEM replacing parts.
Old 12-05-2012, 02:19 AM   #5
yariseggvvti
Finally got the factory alternator in now. Running fine and no more battery light on and off. Spend little extra money taking care the problem is worth.
Old 12-05-2012, 06:36 AM   #6
What did you do with the bad one? I'd like to take a look at one of the aftermarket ones to see why the heck they all act this way.
Old 12-05-2012, 07:03 AM   #7
bronsin
bronsin's Avatar
Next time go to the on line junkyard and get an OEM part.with 30k miles on it.
The alternator, water pump, calipers, master cylinder, exhaust system and in fact everything but the MAF and brake pads/shoes on my sons 2000 ECHO with ~180,000 k miles on it are origional.
Old 12-07-2012, 02:51 AM   #8
yariseggvvti
I return it back to Autozone. I am using it for about two weeks.
Old 12-07-2013, 03:57 PM   #9
Ecoman44
Drives: 2007 Yaris Hatchback Manual
Reviving an old post because I have a similar issue. I have an aftermarket alternator, but it's been in the car (2007 Hatchback) for over a year now with no issues until now. Occasionally, the battery light and airbag light will flash on then off (sometimes just the battery light). When it happens, I can hear a difference in the load on the engine (slight, but it's there). When running, volt meter on the battery reads 14.5v +/- and when not running it reads 13.3v +/-. Could this be the same corrosion issue with the regulator?
Ecoman44 is offline   Reply With Quote
Old 12-07-2013, 05:54 PM   #10
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Could be intermittently sticking brushes - easy enough to check if you're up for dismantling the alternator.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 12-07-2013, 05:56 PM   #11
Yes. The alternator is definitely bad. Many of the aftermarket ones are just refurbished or recycled OEM ones. I have a couple of spare alternators on hand if you need one.
Old 12-07-2013, 06:22 PM   #12
Ecoman44
The one I bought had a lifetime warranty, so let me see what I can get accomplished that route, then I'll contact you if I need one CTScott. Thanks!!
Old 12-07-2013, 11:09 PM   #13
There you go - Definitely hit up the lifetime warranty.
Old 12-11-2013, 09:36 AM   #14
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Yeah, for alternators, I would check locally to see if you have a rebuilder nearby. Then, take your original and have it rebuilt, or have them install one they rebuilt. With aftermarket quality varying greatly, Napa has been up and down on quality as is with O Reilly's. But never want a pump (power steering/water/any) or (starter/alternator) electrical motor from AZ or ADV. They are mostly junk, hence the lifetime warranty.
The absolute best route is a local rebuilder, we have one in town and they are great.
Old 12-13-2013, 02:11 PM   #15
Ecoman44
So, since I hate it when folks don't come back and report on what fixed the problem, here I am. Replaced the alternator, under warranty and at no additional cost, and all is well. We do have a shop here that I have had rebuild starters and alternators before, but I went this route as it was the quickest way for me to get my dependable mode of transport back on the road. Thanks for the help!
Old 12-13-2013, 02:18 PM   #16
+1
Old 03-20-2014, 11:18 PM   #17
Miryai
Drives: 2008 Toyota Yaris HB
I hate necro'ing a thread, but it seems I'm having a similar issue.
I just replaced my alternator (I'm on my fifth one...in about 2 years.) I've replaced the battery recently. I'm getting the battery light, my airbag light and my power steering light on.
All 3 lights will go away after awhile, but whenever the power steering light comes on, even going 40mph+ the wheel will lock up, and I can't move it. It's becoming more of a safety concern now.
I've also noticed that my headlights will also be quite a bit brighter.
I've had the alternator and battery tested in the past week and everything is "functioning" as it should. All the numbers match up to what should be standard. All the mechanics I take it to, think I'm crazy, until I show them the videos I've taken of it happening.
I've also recently blown threw a new set of headlights. All 4 filaments were burnt out, but no fuses needed to be replaced.
Miryai is offline   Reply With Quote
Old 03-20-2014, 11:38 PM   #18
Do you have any way of measuring the voltage when the car is running? You can purchase the little volt meters that plug in to the lighter outlet for about $5 on ebay, if you do not. It would be interesting to see what your alternator is putting out. From the behavior you describe it sounds like it may be running over voltage instead of under.
Are you are purchasing aftermarket alternators?
Also, have you checked the ground straps between the engine and chassis? Since the engine is mounted with bushings, those straps are the only ground for the alternator.
DIM battery light 2o6 DIY / Maintenance / Service 9 11-22-2012 06:58 PM
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 07:21 AM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
