Old 03-27-2007, 05:38 PM   #19
ChinoCharles
Drives: LB
I know, but I've been surprised by the differences in the two before. In theory it shouldn't be any different from platform to platform as long as it has the 1NZ.
Old 03-27-2007, 05:39 PM   #20
ChinoCharles
Drives: LB
For those of you complaining about the rough idle, I switched over to Royal Purple 5W30 full synthetic today and it was idling smoother. Just an idea...
Old 03-27-2007, 05:40 PM   #21
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
well, from what I read in the DIY and what I know of mechanics/electrical, I would say good places to ground are firewall next to the ecu, starter,alternator, the throttlebody(its on the other side of the engine away from the ground on the alternator)or somewhere on the engine close to it,and maybe a couple places on the fenders or chassis.
I am really not sure if it makes the ignition more consistent as everyone says it does, but I know it helps the starter and alternator last longer, and helps if you have a aftermarket stereo.
Edit: there is already a DIY in the DIY manual from this site. really all you have to do if you want to make your own, is go down to a local stereo shop and ask if you can have or buy for cheap some of their scraps of wire they have laying around. then make a distribution block from some steel and you are set, all you need is some bolts and metal screws, some light gauge steel, and some 10 gauge+ wire...
Old 04-03-2007, 11:10 PM   #22
joey1320
joey1320's Avatar
Drives: Yaris LB
Originally Posted by forpinks View Post
SOMEONE DO A DIY!!! please...
and will it help my 03 Corolla on that weird idling speed???
I just changed my plugs,cleaned MAF,replaced Tranny oil,flushed/replaced oil&filter with synthetic mobil1,cleaned and re-oiled the reusable filter, cleaned throttle body,ported polished and high heat painted header,raised the idle speed to 900rpm, and still it seems to go back...
Also I checked my battery,checked for engine code and alot more stuff....
prob not. all it does is provide a better current/less resistance to ground. which will probably not help your idle at all.
joey1320 is offline   Reply With Quote
Old 04-04-2007, 12:02 AM   #23
eijikikimaru
Q(','Q)
eijikikimaru's Avatar
Drives: 3dr Meteroite
I could have sworn someone already did a DIY
And here it is
http://www.yarisworld.com/forums/sho...rounding+wires
eijikikimaru is offline   Reply With Quote
Old 04-04-2007, 09:00 AM   #24
Originally Posted by eijikikimaru View Post
Exactly, and didn't Chris07LB sell his own homemade kits at very good prices?
Old 04-04-2007, 10:18 AM   #25
ChinoCharles
Drives: LB
It wasn't Chris, but yes, someone did.
Grounding kits 07WYarisRS Items for Sale by private party 55 07-28-2007 04:08 AM
HID Light Conversion Kits - $170 shipped! MobileHID Sponsors Classifieds Area 120 05-02-2007 09:04 PM
What's the difference in the Door lock Kits (wire and rod) mgthompson General Yaris / Vitz Discussion 5 03-19-2007 01:29 AM
Yaris Body Kits???? SamSam Cosmetic Modifications (Exterior/Interior) 23 01-15-2007 03:38 PM
GROUNDING KIT DIY? SEaton DIY / Maintenance / Service 73 10-22-2006 04:03 PM
