![]() Drives: Flint Mica Yaris Sedan Join Date: Aug 2006
My 2007 Yaris just started lighting up the Brake & ABS lights when I drive. I read through the entire post about this issue with the Canadian model, and cleaned and greased the contacts (rear for now, didn't have to time to disassemble the front end).
I got the DTC code from the blinks - 3494. Do I read this as 2 different codes, i.e. 34 & 94? If so, does that translate to "Left Rear Wheel Speed Sensor Signal" and "Control Module Communication Bus OFF?" This seems to have started after my battery died (winter sucks), and I had to jump. Any chance of that causing the issue? |
That is correct that it is two separate codes. Did you try clearing the codes to see if the 94 stays off?
Short 4 & 13, turn it on and pump the brake 8 times? Didn't seem to work, but I'll give it another shot.
#4 | |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
| ABS and "!" lights are ON again! | onizuka | Canada | 457 | 04-28-2023 09:40 AM |
| abs light on | brieghne | DIY / Maintenance / Service | 1 | 02-23-2012 08:30 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
| Toyota Yaris -06 VCC and ABS light went on? | goedafred | DIY / Maintenance / Service | 4 | 03-01-2011 12:22 AM |
| custom third brake light? | NinjaPirate | Cosmetic Modifications (Exterior/Interior) | 3 | 11-12-2010 01:16 AM |
