Old 01-10-2013, 05:55 PM   #1
DJPaneno
Drives: 07 Yaris Sedan
Spyder Projector Headlights
Has anyone had an experience with these projectors?
http://www.spyderauto.com/product.ph...adlights-Black
After combing threads/posts I haven't found anyone saying that they have specifically tried these out.
These are for the '07 Yaris Sedan, not hatchback.
Thanks!
DJPaneno is offline   Reply With Quote
Old 01-10-2013, 07:23 PM   #2
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Projectors like these typically have less light output than stock headlights, only benefit to projectors would be with true hid lights
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 01-10-2013, 07:30 PM   #3
I sell them, but I don't have them on my car, so I haven't tested output myself. With a stronger bulb they might be ok.
Old 01-10-2013, 10:58 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
not sure about on our car, but I have a buddy that has them on his Cobalt and he likes them. IIRC he did also fiddle with them to upgrade the bulbs to get better output.
Old 01-11-2013, 05:34 PM   #5
DJPaneno
Thanks for the input, I'm definitely considering getting HID's to increase the output on these if I decide to go with em.
Still haven't managed to find any videos or pictures of them aside from on their installation video which doesn't show them installed and lit up.
Old 01-11-2013, 06:40 PM   #6
HIDs with them could lead to melting of the housing since the projector bowls are so small.
Old 01-23-2013, 12:21 AM   #7
DJPaneno
I thought that I posted my reply to this, oops.
Are there a set of projector headlights (preferably with halos), that you would recommend that I would be able to set HID's into without running the risk of melting the projector bowls?
I'm trying to find the best alternative to retrofitting, because I really don't have the expertise to be taking on a job like that ...
Old 01-23-2013, 01:22 AM   #8
You basically bolt these on, and the output on these are really good.
http://www.theretrofitsource.com/pro...roducts_id=227
You can tack on a halo option if you wish from the drop down options selection.
Old 01-23-2013, 06:25 AM   #9
jcboy
Drives: Sedan 07
Do you have acura or lexus headlights available inthe scrapyard? If so, you might want to look into using those for your retrofit. They use d2s bulbs IIRC. Here in manila a lot of DIYers use such projectors for their retrofit. HTH
Old 01-23-2013, 02:36 PM   #10
Depending on which Lexus projector, the mini H1 is actually better. The mini H1 is slightly better than the TL projector imo. I think only the FX projecotrs are better than the mini H1.
Have a look at this comparison: http://www.jvxdriver.com/bixenon_comparison.htm
Old 01-23-2013, 04:24 PM   #11
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Mini H1 with no foreground limiter - still excellent choice.
FX with foreground limiter - see the more concentration of light and no foreground light. Great setup - super wide beam.
More comparisons shots
All in all - the H1 is an excellent projector for a retrofit. MUCH better than any of the eBay projector headlights you can buy. FX is harder to retrofit - Did the FX retrofit on my 4Runner. Usually requiring some cutting of the headlight where the MINI D2S and H1 are a straight 'drop-in'.
I'm using the H1 in my retrofit over the Popular D2S because I like the output and beam pattern better.
JustDidIt is offline   Reply With Quote
Old 01-23-2013, 04:44 PM   #12
JustDidIt
JustDidIt's Avatar
Here is someone who bought the eBay projectors for the Prii - worthless beam...
Old 01-23-2013, 05:31 PM   #13
Yeah, the mini D2S' output and spread is no where as good as the mini H1. I'm not happy with my G1 bolt ons, seems to be like the output and spread as that eBay one you posted, so I'll either be getting the mini H1 in the future, or if I have time, going with one of the FX projectors.
Old 01-23-2013, 07:50 PM   #14
vten
If you don't mind doing fully retrofit, the Lexus 460 bixenon is one of the brightest and widest angle available on the market right now . The only thing is the dimension that a little too big for most .
And those are actually one that'll be fine using the 55w and up bulbs n ballast, since the bowl is large enough to dissipate heat.
Old 01-23-2013, 09:04 PM   #15
^ how big are those?
Old 01-23-2013, 11:47 PM   #16
vten
I believe they're 3" , but the housing is even bigger than the TL's
I found the JDM LS460 bix, and i was going to play around with them, but chickened out :)
Old 01-24-2013, 12:41 AM   #17
lol, makes me wonder how big the reflector bowl is.
Old 01-24-2013, 03:10 AM   #18
DJPaneno
So, if I am seeing this correctly, it is a kit, so I would be doing my own retrofitting with this. I really am not proficient in working with cars, and doing a retrofit seems out of my league at this point.
On this site will they do the retrofitting for you and ship it in the housing, ready to go, or is this as I'm seeing it - a kit?
Besides eBay projectors, which I don't plan on ever gambling with, is retrofitting the other option at this point?
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
Spyder Auto 06-08 Toyota Yaris Sedan Headlight/TailLights FREE set in SoCal!!! rmota83 California 14 03-24-2013 04:41 PM
CF vinyl roof, Spyder LED tails, whole car repainted 4x4Dragon Cosmetic Modifications (Exterior/Interior) 6 05-14-2012 11:39 PM
Canadians with Spyder Halo Projector Lights SeriousBlack Canada 13 11-29-2011 08:04 AM
