Old 01-25-2013, 07:34 AM   #1
DevilGirl
Drives: 09 3dr LB MT
light not working on heat control
I tried searching for an answer to this question, but could not find one (unless I'm using the wrong search terms...).
Just recently I noticed that one of my heat control knobs no longer lights up. I have a 2009 hatchback, so my control knobs are vertical. It's the bottom one that controls the temp setting.
Any idea on how to fix this so it lights up again? It wouldn't be such a problem other than the fact that when I drive to and from work, it's always dark out (4:30am leave home, and back in my car for the drive home anywhere between 5:30pm and 7:00pm).
Old 01-25-2013, 08:17 AM   #2
There is a tiny bulb on the back of the knob assembly. You remove the two vertical trim pieces, pull off the AC control panel, and then gain access to the back of the knob. A small flat blade screwdriver can then be used to remove the bulb (which is mounted in a recess in the center of the back of the knob).
Old 01-25-2013, 12:42 PM   #3
33OH
Drives: '08 Yaris
Or, I had same issue. CD player wiring was shorting out the fuse for the climate controls. Replaced fuse and tidied up wiring and it all works now.
Old 11-22-2013, 07:08 PM   #4
DevilGirl
Randomly it started working again without me getting a change to "fix" it. It's actually stopped working again.
As for your suggestion of the fuse, if that were the case, wouldn't all the lights not work for the climate controls? In my case, only the 1 didn't work.
Old 11-22-2013, 08:46 PM   #5
That is correct. With yours only having the issue with one of the lights it is more likely a loose connection. Or, the going back to working for a bit may have been a case where the bulbs filament opened (when it stopped working) and then at some point the loose filament flopped into the correct position to temporarily start working again. With the tiny "grain of rice" type bulbs that can actually happen.
Old 11-22-2013, 09:12 PM   #6
nookandcrannycar
Same thing happened to me earlier this month (see my post on the Control Arm Bolt thread from a few minutes ago), except that mine 'stayed back on'. My first thought = exactly what CTScott is saying..loose connection.
Issue on rostra cruise control. Stopped working!! marcus DIY / Maintenance / Service 1 03-25-2012 04:42 PM
DIY Cruise Control for 2012 European made Yaris CTScott DIY / Maintenance / Service 1 12-27-2011 06:47 AM
HELP / Spoiler connecting light SimTronik DIY / Maintenance / Service 4 11-02-2010 11:08 PM
light bulb for fan speed control burned out bankrobber DIY / Maintenance / Service 2 09-08-2010 05:37 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
