![]() Drives: Yaris Join Date: Jan 2013
New Battery
Hi! Nice forum you got here!
The battery in my GF's Yaris is dead. Instead of letting her go to the dealer and pay full price for a new one (I also wanted to be her hero) I went at Costco and bought a Kirkland battery, cause, well, I CAN replace a battery by myself. Now, two things: 1- The battery is like ¼ of an inch taller than the old one, I can't fit the hold-down kit unless I remove the plastic tray under the battery. Is it safe (for the battery) to install it without the plastic tray, directly on the metal? 2- While unscrewing the hold-down rod, well... I was not holding it... Thank you guys! Mart |
![]() ![]() Drives: Toyota Yaris Join Date: Aug 2011
I would get an OEM battery personally. But I would keep the plastic tray and make sure you find the hold-down rod because it's not good for a battery too vibrate at all while driving. The more secure the better.
You might be able to get a longer set of aftermarket battery tie-down rods from your local autoparts store, but I would definitely go on the search for the dropped one, as floating around it could end up someplace where it could cause issues.
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
I agree, the OEM batteries are not that much more but optimized for Toyotas.
![]() ![]() Drives: 2008 Hatch Red Join Date: Apr 2012
My new battery was a bit too tall (not Toyota) and I was able to modify my tie down by bending it to fit. Not difficult to do and I still have use of the hood prop holder.
Sears DieHard Platinum P5 is a perfect fit.
Thanks. Like andulong I was able to fit the battery by bending the tie down. And I finally found the rod and got it out with a magnet. Simple solutions! No regrets buying the Costco battery.
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| Charging voltage for stock battery | Vinceb | DIY / Maintenance / Service | 3 | 02-12-2011 12:10 AM |
