#19 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
I hear you, CASTREX, and all I can say is this:
1) None of those articles ever took rolling resistance into account. 2) None of those articles looked at actual tire longevity. 3) These articles are usually written by the same folks that swear to this day that you absolutely must change your oil every 3,000 miles when Toyota says 5,000 - 7,500 (depending on the engine) and extended synthetics say 12,000 - 15,000. 4) Very few writers, or the organizations behind them, do their own science. They simply mimic what has been published elsewhere. 5) Don't forget that pumping the tires up higher greatly extends tire life so it goes directly against the interests of tire companies, tire sellers and tire installers to have you use a higher PSI. 6) Try it for yourself rather than letting others make the decision for you. However, if you don't want to pump up your tires you certainly don't have to. Like all other hypermiling facets it is left to personal taste. Just know that Prius owners typically run around at 42/40 PSI on tires that are listed for 35 and several of us on CleanMPG.com are running around at 50+ not only without problems but with many tangible benefits.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#20 |
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
Pumping tires up higher than normal wears the center of the tread out faster, underinflated wears the outer edges of the tire out...at least with normal matched wheel and tread width. Granted the Yaris is light so wear will take a long time to show.
Sorry Bailout but I value my life more than a couple miles per gallon....in the midwest you won't catch me doing 55 in a 55 limit, I'd get run off the road...and in the 75 zones, 75 to 80 is a safe feeling. |
#21 | |
#22 |
![]() ![]() ![]() Drives: 07 yaris s sedan Join Date: May 2006
i guess thats my problem....i can't drive 55.....LoL
2007 S Sedan, NF210's, 5% rear windows, 35% front two, Sirius S50, 15" black konig heliums
#23 |
Roar?
i feel ya. i am always doing about 80 in the fast lane but when i get people up my ass i hit 100 or 110 lol NJ has very aggressive drivers. guess thats why insurance is so high here
#24 |
wow, the fastest i've ever driven in my Yaris was 85 mph. LA also has some aggressive drivers.
#25 |
Modded Moderator
Ok, I'm a little fuzzy still on how to use DFCO. (I have an automatic.) So all I have to do is take it out of overdrive, put it into "3" and not press the gas pedal while say, going down a hill? Or do I have to put the key in the "acc" position and follow those steps? Forgive me for my ignorance.... I read through every single post on this and I'm just not 100% certain.... Thanks!
#26 |
Astroman:
There is no need to touch the ignition control. Just put the transmission in 3 or L and let your foot off the accelerator.
#27 | |
Modded Moderator
#28 |
Drives: 2007 Yaris LB Join Date: Mar 2007
BailOut is correct! The A/T Yaris uses Grade-Logic (sorry to use a Honda term), and it works great, but I often manually shift to 3 and 2 to take advantage of (1) DFCO and (2) engine braking to save the old brakes.
| Using DFCO to increase your MPG | BailOut | Fuel Economy Forum | 216 | 08-30-2018 05:15 AM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 09:01 PM |
