Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
Removal of the door panel
There is a rattling noise coming from my drivers side door every time I close the door or hit a bump. does anyone have a diagram or set of instructions for removing the door panel?
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
There's a thread in the DIY section called something like "30 second door panel removal".
well i fixed the rattle in the door, apparently this bracket had come lose where it has foam gluing it to the outside door panel.
i put a few dabs of super glue on the foam and pushed it back where it was, and for added redneck assurance, some duct tape.
Superglue is only for non-porous materials. I would use Automotive Goop instead, which will do a good job of bonding it back in place.
its was dry rotted looking and torn, the duct tap should hold it together. since my budget for repairs right now is 0 i will have to stick with what i did instead of acquiring something else. thanks for the info :D
![]() Drives: 07 yaris 3-door liftback Join Date: Mar 2014
In case anyone is wondering if this is the source of your rattle, here's a video so you can compare the sound to what you've been hearing. https://www.youtube.com/watch?v=Dfza6yZjXUc
| Auto Transmission removal | artichap | DIY / Maintenance / Service | 14 | 10-23-2012 10:27 PM |
| 99 Vitz Hatchback rear outer door handle removal | deadalus | DIY / Maintenance / Service | 3 | 09-06-2010 02:02 AM |
| Removal of the Factory Integrated Source | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 08-24-2010 12:44 AM |
| Weight Savings - Removal, Reduction, Reminder.... | TRD_Yaris | Performance Modifications | 17 | 08-12-2006 02:07 PM |
