Old 02-23-2013, 07:55 AM   #19
kashanf
Drives: Toyota Belta
there is one 2-Pin connector in the both the front door panels which is not connected to anything.. wire color is i think green and white.. what is that connection for? it is just near to the mirror connector.. i doubt it is for heated glasses?..correct me if iam wrong
kashanf is offline   Reply With Quote
Old 02-23-2013, 09:38 AM   #20
ciscobear
I've seen those two wires as well. I suspect they are for our optional mirror indicator upgrades. Will post a pic later.
ciscobear is offline   Reply With Quote
Old 02-23-2013, 09:44 AM   #21
kashanf
i tried connecting indicators to that wire..but they are not working so i decided to make side mirror indicator connection to the side fender indicators..that 2-pin is for something else..may be some expert can tell us what are they for..
Old 02-23-2013, 09:59 AM   #22
The extra wires are probably for the power folding mirrors, which are an option on Japanese Yaris.
Old 02-23-2013, 10:11 AM   #23
kashanf
no thats not for folding..my belta comes with 5wire connector (auto folding).. this 2-pin is separate connector
Old 02-23-2013, 10:18 AM   #24
OK. If it is not the attached one, then it probably is the one for the turn signals. With some of the wiring like that, the harness is in the door, but the connection between the kick panel junction connector and the fuse panel is not there.
Old 02-23-2013, 07:16 PM   #25
ciscobear
Old 02-25-2013, 10:27 AM   #26
kashanf
this is the same connector i also have in my belta door panel.. did you find any information about these two wires?..i need to connect my Mirror Led indicators.. iam thinking to wire them to the fender indicators .. i wish this connector can be use for led indicator..if you found any information then let me know:)
Toyota Australia releases YRX SEDAN. Sp33dY General Yaris / Vitz Discussion 1 08-01-2006 01:19 AM
Belta/Yaris Sedan compatibility fnkngrv General Yaris / Vitz Discussion 2 07-24-2006 06:02 PM
