![]() ![]() ![]() Drives: Black 07 Toyota Yaris Sedan Join Date: Oct 2009
Power Mirror Wiring
My 07 sedan doesn't have the pre-installed wiring for the power mirrors. I can figure out how to wire it myself, but my question is; does anyone know how much voltage should be running through the switch? Thanks in advance
![]() ![]() ![]() Drives: Yaris sedan Join Date: Apr 2011
as elsewhere 12V
I like very much travel |
Is the wiring missing in the doors or is it missing for the switch?
Really? I wonder if that is a sedan thing, as the liftbacks without power mirrors definitely are prewired. I wonder if anyone else with a non-power sedan has tried upgrading the mirrors?
To see the door wire connector you have to pull the door panel: Mirror Connector.jpg The switch connector was taped to the harness at the top of the under-dash fuse panel: Switch Connector.jpg If you remove the driver's side kick panel and look at the bottom connector, do you have the black and sky blue wires on the top left of the connector shown here? Kick Panel Connectors.jpg
#7 | |
MicZel has an 07 Sedan, that was a USDM Yaris that eventually made its way to Russia. His is pre-wired, as I am in the process of sending him a care package to convert his mirrors to power.
The next time I remove my door panel, I'll see if mine is pre-wired as my car came with nothing, no power anything, no ABS, etc. I'll try to look tomorrow at the interior fuse box to see if I have those wires.
@CTScott
I have no such wiring :( |
Interesting. If you still want to use the power mirrors, I have the harness from the switch to the mirrors available. You would then just need to run the three wires from the kick panel into the doors.
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Hmmmm... This is the single one issue that irks me the most about mine, that there aren't even manual remote adjusters for the mirrors. If you're saying they're pre-wired... I'm gonna go and check :)
#12 | |
The package contained all kinds of goodies! For the power mirror conversion, literally all that is required (provided that you car is pre-wired) is the remote mirror switch ($50 to $100 depending on new or used) and about $40 each for good quality, new, aftermarket mirrors.
So, like these?
http://www.ebay.com/itm/Outside-Side...b0e26b&vxp=mtr Image for future reference: http://i.imgur.com/0bNTJqh.jpg |
#15 | |
#16 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
also, i havent checked the skyblue and black wires that you mentioned, but i don't have the big connector hidden anywhere near the junction box (behind the removable sunglass holder (?))
#17 | |
For the turn signals, you would have to wire them directly to the wiring that feeds the front and rear turn signals. I could do $30 + shipping for the harness, including the two extra pins.
why do you know more than i do about my own car?
LOL. yes i don't have those sky blue and black wires on the kick panel. just wondering, isnt the retract supposed to go into a module (that the switch's retract button activates)? thanks for the quote, i don't have money to burn yet for this upgrade, (although i can afford the wiring, thanks to you) i'll let you know once i've saved up for the mirrors. |
| kuro-kuro, mga sarisaring katanungan | xtremist | Middle East | 2740 | 01-27-2020 03:36 AM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| Yaris Verso: Reset power window jam protection | togo | DIY / Maintenance / Service | 3 | 01-10-2013 10:03 AM |
| DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS | julienrl | DIY / Maintenance / Service | 1 | 08-31-2009 10:06 AM |
