Old 02-26-2013, 08:19 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
TWM Short Shift Kit!
So I pulled the trigger on a TWM short shift last week and finally put it in today. Wow, crazy short. Combined with the MI engine-side SSK, it's super stiff and notchy, but very very short from front to back. I can't say how it compares to the MI shifter extension, but it's at least 2" shorter above the ball, meaning you're going to get some strong arms from rowing that beastie. I would have taken pics, but the install instructions are 95% spot on, and the pictures on their site show the product as shipped.
Old 03-03-2013, 12:21 AM   #2
So the shifter is shorter physically, not just shorter travel?
Old 03-03-2013, 07:36 AM   #3
CrankyOldMan
Yup. I was in too much of a hurry to get any pictures taken for comparison, but I did at least look at them side-by-side when swapping the plastic ball cap. The upper end is shockingly shorter, though the lower end is only about 1/4" longer. Too much longer and I would expect issues with hitting the floor pan.
The boot cover now sits much lower, so it looks a bit funny. Almost like your pant legs when you're sitting on the toilet. The OEM boot support clip does not engage properly on the shaft, so I had to improvise with a 7/16" ID rubber grommet. I also bought a foot of 1/2" ID clear flexible tubing to make a standoff sleeve in the event that the grommet doesn't stay put.
I'll see about getting some pictures without the boot on this afternoon.
Old 03-03-2013, 07:52 AM   #4
thefalls
Drives: Axio GT
I hear that after driving around a bit it gets better. So lets wait a bit.
I have been thinking about the short shifter,i think will go with the MI in-cabin and engine side combo. Will have to inquire about shipping sometime soon,Garm.
thefalls is offline   Reply With Quote
Old 03-03-2013, 01:40 PM   #5
TOLMACH
Drives: soarer
Any chance to take any pics?
Is it getting better? Do you plan to keep it?
Thanks
Old 03-03-2013, 02:09 PM   #6
I wouldn't want my shift knob to be lower, I use an extension to bring it closer to the wheel -- but it's a matter of taste and arm length, etc.
Old 03-03-2013, 05:33 PM   #7
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I've actually extended my shifter 3" and am seriously considering going 2-3" more. I have the engine bay SSK and am considering the in cabin SSK.
I couldn't imagine my shifter being lower than stock. I think it is too low even now with the extender. I also added the armrest which makes it uncomfortable to have at the stock level. I like the armrest.
Old 03-03-2013, 06:32 PM   #8
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
(hint hint...
Here, I'll help to get things started. Here's my shifter...
Old 03-03-2013, 07:10 PM   #9
CrankyOldMan
OK, here's a few pics!
It's so low that you can see the frame of the shifter body around the base!
Here's the OEM shift lever, measured from the top of the ball to the end of the threads. Keep in mind that I measured backwards because zero on this ruler isn't at the end. OEM = 9.25"
Here's the TWM as installed. The flash on my metal ruler made for some extra crappy pictures. TWM = 6.5"!
I'm definitely keeping it, but it's taking some time to re-train my muscles. It's still a bit awkward getting it in to reverse, but the 1-2 and even 2-3 shifts are crazy fast! I do, however anticipate some response issues when I start autoX this summer--it's a LONG way from the wheel to the knob.
Last edited by CrankyOldMan; 08-20-2014 at 10:19 PM. Reason: Pictures were stupid big.
Old 03-03-2013, 07:16 PM   #10
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Tooter, I take it that is stock? Mine is 100% stock. Wouldn't mind it being physically lower. Had a friend with an eclipse and the kit made his shifter maybe 3 inches long at most. Of course the eclipse use to be a real sports car, with the shifter nice and high.
Colin Chapman disciple
Old 03-03-2013, 09:41 PM   #11
tooter
play every day
tooter's Avatar
Yeah, it's just the stock lever with an old school 1960's style Hurst "Cue Ball" shift knob stuck on it. The smooth round shifter feels really nice.
Old 03-18-2013, 06:41 AM   #12
CrankyOldMan
Almost three weeks of daily driving and I'm getting really comfortable with it. I even tend to use just my index and middle fingers to shift from 1-2, since it's a faster movement than rowing my whole arm. There is still some awkwardness getting in to reverse and neutral, but I can live with that.
Old 03-18-2013, 02:36 PM   #13
TOLMACH
Drives: soarer
^ Glad to hear that
Thinking about one myself.. My problem though would be with hight of this thing. The oem just works perfectly for me (in terms of height).
Old 03-18-2013, 02:57 PM   #14
kou
Drives: 08 lb
^ I have had one in since 07 I have a 5'' extension and the throw is still shorter than stock
Old 03-18-2013, 08:50 PM   #15
CrankyOldMan
Well, it sits about level with the seats, but the throw is so short you don't have to reach very far forward.
Kou: interesting knob. what is it?
Old 03-18-2013, 09:35 PM   #16
kou
Drives: 08 lb
^ It's a stock subaru impreza wrx maybe 2004 shift knob it even has the same shift pattern and thread.
Old 03-19-2013, 09:20 PM   #17
TOLMACH
Drives: soarer
http://www.ebay.com/itm/TRD-Gear-Shi...fc4f02&vxp=mtr
Old 07-25-2013, 01:45 AM   #18
jimhimbo
Drives: 08 Blue yaris liftback
How do you remove the top plastic piece that holds the middle ball of the shifter in place? which is needed to swap stock with twm shifter.... TWM's instructions show a different type of plastic containment piece with tabs...but I can't figure out how or where tabs that can be depressed are on our setup..yours is the same as mine 08...thats the only piece of info i need before i order mine! thanks
jimhimbo is offline   Reply With Quote
Micro Image Short Shift Kit DIY jpmck03 DIY / Maintenance / Service 17 02-24-2014 07:57 AM
Back to school sale Short shifter, Shift Knob, EVERYTHING is on sale! TWM Performance TWM Performance 13 09-29-2009 10:55 AM
New shift knobs available from TWM Performance! TWM Performance TWM Performance 3 06-25-2009 04:24 PM
TWM Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 9 08-28-2006 03:37 PM
TWM Short Shifter/Shift Knob Sale! TWM Performance Performance Modifications 0 07-17-2006 05:08 PM
