![]() Drives: 2006 Yaris RS Join Date: Dec 2012
Intake Size!
Im wondering how big my intake size his on my 2006 yaris! Anyone have any idea!
Im wondering if this his the size.. 2.5" ~ 3.0" (65mm~75mm) |
I have a 2008 yaris (US) and here is my intake box at the MAF sensor. I assume you have the same 1.5 liter (1NZ-FE) engine.
it is ~2.25 inches and just under 60mm (I'd say around 58 or so) though the metric picture came out like crap. the size at the MAF is very important for the ECU.
thanks man!
play every day
The measurment in the pic is slightly larger the actual diameter because it's at the expanded flange. The intake diameter at the MAF sensor is 2 inches. You can put anything else on either side of the sensor section...
![]() ...as long as right where the air passes through the sensor remains 2 inches. |
Thanks tooter.
it was a very impromptu picture and I definitely don't want to tell someone wrong. I have a pair of calipers at work that will do depth measurements, but they were at work. |
2.25" is stock, and is pretty much gospel to be the max. You can deviate under, but very rare is there any success going over 2.25".
play every day
I measured my stock air box and the two aftermarket intakes and they're all 2 inches at the sensor. The area in front of the sensor commonly increases to 2 1/4.
Intrestingly, this Injen appears to be larger than 2 inches at the sensor because it gets smaller between the sensor and the throttle body... ![]() ...although some intakes flare back out right at the coupling. My Simota intake tube is like that and needed a reducer to make it fit the stock throttle body... ![]() The area in front of the Injen sensor looks to be at least 2 1/2 or even larger. Last edited by tooter; 03-13-2013 at 02:36 PM. |
#8 | |
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
#9 | |
play every day
![]() ![]() Drives: 08 Yaris AT, 350Z GT MT Join Date: Feb 2013
That one is 3" and will make the yaris have all sorts of issues. you could buy a knock off yaris intake from ebay and hope it is the right diameter.
the ECU on the yaris is very funny about the intake size at the MAF. ****edit**** Crap, I didn't realize he didn't have a yaris.... my bad. |
gab25diygarage
Drives: 2017 yaris NCP150 Join Date: Oct 2020
please do not buy a knocked off air filter ...not doing its job well trust me after a month check your throttle.
never change the diameter pipe of the MAF sensor the oem its design is already programmed on the ecu. if ever you have change the air and fuel mixture will be rich or lean either way you loose power. if you want to change because you want to gain speed well you really need to remap your ecu.(after upgrading the intake, exhaust etc...) take note: upgrading your intake you must also upgrade you exhaust then to be safe and sure things has change and you can testify as well because it has a record, do the "remapping". |
| tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
| intake size | lunarcrusader | Performance Modifications | 6 | 11-06-2009 02:20 PM |
| The great intake debate! | fmicle | General Yaris / Vitz Discussion | 74 | 10-06-2009 11:37 PM |
