Old 03-16-2013, 08:16 PM   #19
hw6515
Drives: 08 Yaris AT, 350Z GT MT
Pretty much done with the 80k miles maintenance.
Items replaced so far:
Water pump, water pump pulley and belt.
Shocks and springs >>> tokicos red in the front, blues in the back with MR springs.
PCV valve.
8Qts ATF + Transmission filter. (in two steps, 4qts at a time)
Spark plugs.
Fusible link, + and - battery connectors.
Added:
Oil catch filter.
Cleaned:
Intake Manifold.
1 Valve.
hw6515 is offline   Reply With Quote
Old 03-17-2013, 09:06 PM   #20
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
The "dirt" is clutch pack material, pretty normal.
A UOA on ATF is pretty meaningless, as there really is no much oil breakdown due to no exhaust blow-by infecting the oil.No pistons scraping cylinder walls, causing metal shavings.
The fluid pretty much is used for fluid pressure, and to keep bands, and clutch packs lubed, that's why it can go 100K miles.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 03-21-2013, 12:55 PM   #21
hw6515
Gasket part number for transmission and oil plug.
Old 03-25-2013, 09:53 AM   #22
hw6515
The oil catch filter does work, less than 1k miles at the time of the pic.
ATF looks clean also, if now the transmission last 50k more miles it wont be wasted time and effort.
Old 03-25-2013, 10:03 AM   #23
Yarflana
Drives: 2008 Base Model
This may have been previously stated, but I didn't see anywhere in my manual for my 2008 Hatch base model on how to check the transmission fluid level, or anything like that. Would that imply is doesn't need changing according to Toyota?
I guess I would need to look at the required maintenance services intervals and see if it indicates a change is required.
Yarflana is offline   Reply With Quote
Old 03-25-2013, 10:55 PM   #24
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
yea technically Toyota says the transmission fluid should last the life of the car. That is total bs. It'll last about 60k at most, then you should change it.
Colin Chapman disciple
Old 03-30-2013, 03:53 PM   #25
hw6515
Alignment
Did this using: Tamago's guide to ultimate yaris handling.
http://www.yarisworld.com/forums/showthread.php?t=14026
What do you guys n gals think?
Old 06-06-2014, 02:54 PM   #26
LugNut
Drives: 2007 2DR Liftback
In my distant past I worked in a transmission shop. Changing the fluid and filter were routine maintenance, and most people waited too long. Need/frequency depends on several factors; I can tell by the color and smell of the fluid when it's time for mine.
I just changed my 2007 hatchback's at 54,200 miles, and it was definitely time. Required about 3.5 quarts of Toyota ATF WS. I used a Fram FT1220 filter kit that was less than $14 from RockAuto.com, plus shipping. Looked just like the original. As mentioned, the filter _does_ have filter-media, and is not just a screen.
I like the provided drain plug in the pan. That will encourage me to replace a few quarts every year or two, but I likely won't change the filter again for many years.
LugNut is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
Should I change my brake fluid? lh59 DIY / Maintenance / Service 4 06-27-2012 12:48 AM
1st oil change ; At what miles ? Hershey DIY / Maintenance / Service 42 02-03-2010 05:46 PM
2008 Yaris AT Fluid change Rutherfordman General Yaris / Vitz Discussion 8 07-13-2009 01:45 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 04:40 PM
