Old 03-21-2013, 11:31 PM   #1
Yarflana
Drives: 2008 Base Model
NHT brake calipers - OEM replacement
I am looking to just replace my stock front brake calipers with lighter, better performance calipers.
I looked at Wilwood, but they do not seem to have Yaris fitment.
Here are some I like the looks of, but I am wondering if the benefit stops at the looks, or are these lighter and better performing calipers than stock.
http://www.buybrakes.com/p-681-nht-c...-calipers.aspx
Let me know your thoughts as they are much appreciated.
Pat
Yarflana is offline   Reply With Quote
Old 03-22-2013, 05:58 AM   #2
bronsin
bronsin's Avatar
According to the description they are just pretty colors that wash off easily!
Old 03-22-2013, 07:34 AM   #3
Yarflana
Respectfully disagree with you. Some one who has either bought these or knows a mechanic that has worked with them is what I was after with my question. There is some reason these are $400 more than a pair of OEM stock and paint cannot be that full difference, else they would not be able to stay in business.
I frnakly was looking to replace my stock calipers with a lighter caliper, if avaliable.
Maybe I will venture over to Garm's forum and see what they have on caliper replacement.
Old 03-22-2013, 08:02 AM   #4
If you look at the close-up picture of the red ones on their website, they have the Ford logo on them, so they are likely just remanufactured calipers.
Old 03-22-2013, 08:25 AM   #5
Yarflana
Ok much appreciated...so if one were wanting to replace the stock calipers with a higher performance caliper, but keep it at the stock size (just bolt on the stock size rotor) what would you go with?
Old 03-22-2013, 08:35 AM   #6
I don't think that you will find anything higher performance without going to a setup that is a complete replacement with larger rotors. With how light the Yaris is, I don't think that you will find any type of upgraded direct replacement calipers that are dual piston, etc.
A while back there was a discussion about lighter rear drums as well. I ran into a website for a company that makes lighter ones, but when I spoke with them about the Yaris ones they had listed, it turned out that they were exactly the same weight as OEM. Their actual lighter ones were the much larger ones for trucks and older muscle cars.
Old 03-22-2013, 08:38 AM   #7
Yarflana
Ok makese sense...thanks. I contemplated going to a larger rotor, but seeming it would not be for any racing application, I am just replacing the rotors, pads, drums and shoes and leaving the calipers and cylinders be until they wear out.
Old 03-22-2013, 10:43 AM   #8
^ That is the best strategy. Reading through Jason's threads will demonstrate that even on a full race car, he's using stock calipers.
Wilwood does not have a replacement. You'd need to match an existing Wilwood caliper to the stock rotor (diameter and thickness), then fabricate a bracket to hold it in the correct position.
Old 03-24-2013, 11:30 AM   #9
Viperoni
Drives: 2005 Toyota Echo
Straight from the NHT link you provided:
"The NHT Calipers start out as OEM Brake Calipers that are remanufactured with brand new hardware, and then given an extremely durable powder coat finish that will outlast any painted caliper."
Stainless Steel brake lines are a great addition.
Also, for road racing, if you're not boosting, you don't need anything more than the stock caliper + rotor with EBC Yellows / Hawk Blues.
Getting some more cooling to the brakes would help bunches, and that's something I'll look at this year on my Echo. After a couple of hard lapping days, I'm getting a little too much of the pad-edges breaking apart.
For street use, good pads are all you need to spend money on.
2006 Saturn Ion Redline
Old 03-24-2013, 12:54 PM   #10
Yarflana
Yeah, after rereading I think they are not giving a lot of additional benefit. I guess with the BBKs on the market, it doesn't make sense to supe-up a 4 piston OEM type caliper and it is likely you cannot get much additional performance from only 4 pistons unless you enlarge them.
Old 03-24-2013, 01:59 PM   #11
racerb
I have Road Raced lots of different FWD racecars over the years all using stock brake calipers. Your best money spent is on good pads (Hawk/Carbotech), rotors (Brembo,R1 Con.,Centric), brake lines (Goodridge,Stoptech), oh and as others have said proper cooling. Good quality fluid is a must, we always ran Castrol Dot 4/5, but any good fresh fluid bled often will make a big difference. A good set of Speed Bleeders will make life easier when optimizing long time brake performance.
http://www.russellperformance.com/mc/speed/import.shtml
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 03-24-2013, 05:11 PM   #12
bronsin
bronsin's Avatar
Not sure on cars but on motorcycles four piston calipers rule!
Two piston calipers: I feel sorry 4 u!
Old 03-24-2013, 09:11 PM   #13
Yarflana
racerb
Yeah, that's what I decided. On order right now from MI are R1 drums, rotors (drilled and slotted), shoes, Hawk pads, and a racing battery. I already replaced the break fluid with Motul 5.1 and put on stainless lines and adjusted the e-brake.
As of now, with just the new fluid, lines and e-brake adjustment, my pedal is twice as firm and 50% less travel in the brake pedal. With the new pads and shoes, it will be unbelievable I am sure and I won't have to mess with brake fluid bleeding again for a while.
Thanks for all the responses on this. I don't think I would have paid $500 for 4 piston calipers anyway, even if they were "double" the performance.
Old 03-24-2013, 11:12 PM   #14
Those rotors look great, I have them on mine.
Old 03-25-2013, 01:07 AM   #15
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
^ and I'm literally wiping my hands down after installing my set, Hawk pads, speed bleeders and flushed the fluid with ATE super blue. I'll do my lines and drum shoes next week...ran out of steam for tonight. Hehe
-Type 07 FFL-
My odometer 03/11
Old 03-25-2013, 11:59 AM   #16
jetblast
Drives: Gen 1 XB
The $3.50 Harbor Freight magnetic bleeders with check valves work great too. Nice for being able to quickly flush your system once a year.
Why strive for a JDM BB, when you can promote the Scion badge?
jetblast is offline   Reply With Quote
Old 03-25-2013, 12:04 PM   #17
mazilla
advocatus diaboli
mazilla's Avatar
Nice.
I thought about going with an external bleeding device, but @ 7.00 ea for the speedbleeders I just bought the set and one extra for the clutch. They worked perfectly...kinda wish I had done that sooner, especially on the clutch. It makes it super easy to manually bleed.
-Type 07 FFL-
My odometer 03/11
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
OEM roof rack mounting rubber pad replacement Yai Cosmetic Modifications (Exterior/Interior) 3 12-22-2012 12:01 PM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
DIY: Painting Factory Brake Calipers redyaris DIY / Maintenance / Service 38 05-26-2007 08:47 AM
