![]() ![]() Drives: Yaris Sedan Join Date: Dec 2012
How hard I should try to remove spark plug
I am trying to change out my spark plug, as mine has 126000km on it and its still the same one out from factory.
I was trying to unscrew it by a crappy (Canadian) tire spark plug remover (very low quality), but i can't get it loose even by forcing it. Obviously I don't want to really force it out as its possible that it seized up. My next step is to break it loose by a ratchet/socket (and so I got a 6" extension bar). My question is, how hard should I try undoing it before I take it to a garage for a proper seized-up plugs removal? Sorry if its a stupid question, I am really new to DIY vehicle maintenance. Thanks all! |
![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
It's important to use the right tool.A ratchet with an extension plus a spark plug remover socket. Turn it anti clockwise/ counter clockwise until the plugs loosens up. I would say a firm turn on the ratchet should do the job..
WARNING!! disconnect your negative battery terminal first just in case. |
I changed my plugs not long ago. I used a ratchet, 6 inch extension and a socket that fit the plug. I would ensure that the socket is 6 point, not 12 point if you are breaking anything loose as this gives you the best contact with the sparkplug edges.
My car has 100k miles on it and the plugs came out fine with these tools. One thing I did do when inserting the new plugs is I hand tightened them first with the socket and extension only (no ratchet attached) so that there would be minimal chance of crossthreading. You want to also make sure to torque to the proper ft lbs (about 20 I think). |
#4 | |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Not removing the sparkplugs for a long time can lead to their seizing for various reasons. A brown residue will build up on the threads. If that is the cause forcing the plug out will PROBABLY not take the threads with it.
![]() On the other hand.... If the threads in the head come out with the plugs you are SCREWED! I would wait for people to check in here whether or not the head will have to come off to repair them. ![]() If not...then you just have to have the car towed to a mechanic and pay $$$ to fix it. ![]() With electronic ignition and fuel injection sparkplug life is practically indefinate. If you chose to leave the plug in there Im thinking thats a good choice if you plan to keep the car only a couple more years. You could put the plugs back in, take it to a mechanic and innocently ask to have the plugs changed. If he strips it its his dime. Or he could just pretend he did it... My advice: Put the other plugs back in and drive it. Take it to a mechanic. Good luck and tell us what happens!
#6 | |
![]() ![]() ![]() Drives: Black Vitz Liftback Join Date: Dec 2008
If you're having that much trouble getting one out, it would be way better to have a professional do it for reasons mentioned above. The plug can break. This is why mechanics recommend pulling them every 60k or because they like to weld themselves to the head.
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
stone cold
The engine has to be cold cold cold as with thermal expansion, the heads will hold the plugs when they are warm.
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
I had the same problem with my 87 Accord. I couldn't get the plugs out .. and I bent the Canadian Tire spark plug removal tool as well (yes it does really suck). I actually had the mechanic at Canadian Tire remove / reinstall my spark plugs for me. They did it for free ... must have been a good day as really I pretty much hate Canadian Tire.
I sold the Accord to an auto wrecker a week later (this is when I bought my Yaris). Not my problem now. |
#10 | |
![]() Cold is the default for plug removal. ![]() But sometimes you try it different.
I would imagine installing when the engine is hot vs removing is the risk.
Thanks for all the advice! I will try next time when I have time.
#13 | |
If it wont budge warm the engine up and try it. Ive had time to rethink my advice on this. I suspect you just have a stuck plug that will come out okay once you put the beef to it. But I wont be able to sleep until I hear what happens!
#14 |
Ok :D standard practice first. lucky here in my town is still about 4 degree above zero so its still rather cold for a spark plug change
#15 |
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
I had to google this "crappy (Canadian) tire spark plug remover" to see what you guys are talking about. Throw it away!
Get a good spark plug socket for your ratchet. Although you can use a standard socket (save $$$), spark plug sockets come with a little rubber donut insert to help you from cracking the insulator when installing a new plug. Plus the donut helps hold the spark plug in the socket as you lowering it into the spark plug well; that way your plug won't fall in and possible change the gap. |
#16 |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
plugs
If you only replace the plugs once every 100k miles than yea it would be a good Idea to remove them around 50k miles , put anti-seize compound on the threads, check the gap and re-install. You'll have no problem taking them loose the next time at 100k miles.
#17 |
Here is a quick tutorial for removing spark plugs from the Yaris (and ECHO and many others) Obviously meant for people who havnt done this before.
The picture is the tool you want. A 3/8 inch drive ratchet, a six inch extension in 3/8 inch drive and a 5/8 inch sparkplug socket also 3/8 inch drive. The six inch extension is Shoo Gooed to the sparkplug socket. It is NOT shoo glued to the ratchet! The socket cant be removed from the extension making it a tool to remove sparkplugs only. The 5/8 sparkplug socket has a rubber insert to hold the sparkplug while you unscrew and lift out the origional plug and to hold the replacement plug while you lower it in place. The six inch extension is shoo glued to the socket to prevent the socket from pulling off the extension when removing it from the new sparkplug. When installing the new sparkplug (or reinstalling the old one) spray the rubber insert with WD40. This will allow the insert to hold the plug while lowering it into place and allows to plug to easily slip out of the socket once it is screwed and torqued into the head. The reason for the shoo goo and WD40 is the extension will pull off the socket and stay down in the cylinder head when installling the new plug and tryiong to get the tool out of the hole. Any Questions?
#18 |
If it helps concerning the DIY, I used a pair of needle nose pliers to GENTLY grip the old plug once completely unscrewed and to lower down the new plugs. I used the extension and socket to hand start and tighten the new plugs before putting the torque wrench on the new plugs to about 20 ft/lbs, so basically, you only need the regular wrench for removing the old plugs.
Ensure you check the gap on all plugs (cannot remember the gap size right now) as you cannot assume it is set right from the factory. |
| Spark plugs suggestion | walt101786 | DIY / Maintenance / Service | 29 | 03-05-2023 09:06 PM |
| Spark plug torque | Geoff Peace | DIY / Maintenance / Service | 11 | 05-05-2021 02:48 PM |
| Spark Plug | ubospawis | Middle East | 11 | 09-01-2010 08:55 AM |
| Do we need to regap our spark plug? | marcus | DIY / Maintenance / Service | 2 | 08-31-2010 10:53 PM |
| How hard is it to remove side skirts and front lip on 08 sports package? | dono37 | Cosmetic Modifications (Exterior/Interior) | 15 | 09-26-2007 05:28 PM |
