Old 04-05-2012, 01:55 PM   #1
Nas_RS
Vitz_RS
Drives: Toyota Vitz RS NCP91
Error Code: PO453
Hello,
Can someone help how to resolve Error Code: P0453, check engine light in on..please help.
P0453: Evaporative Emission Control System Pressure Sensor High Input
Nas_RS is offline   Reply With Quote
Old 04-05-2012, 02:51 PM   #2
That indicates an issue within the evaporative canister back by the gas tank. P0453 could be caused by any of the following:
Canister pump module
• Connector/wire
harness
(Canister pump
module - ECM)
• EVAP system hose
(pipe from air inlet port
to canister pump
module, canister filter,
fuel tank vent hose)
• ECM
Look at page 207 of the Engine Control section of the service manual and work your way down from there for instructions on how to determine what the actual problem is:
http://www.microimageonline.com/foru...32-YARIS-FILES
Old 04-05-2012, 04:25 PM   #3
Nas_RS
Vitz_RS
Hi ..
The Fuel Pump and filter were replaced to new still the error is here, where is the canister situated can it be repair, the ECU is a new one
Old 04-05-2012, 04:31 PM   #4
Nas_RS
Vitz_RS
do you know where the CANISTER PUMP MODULE is? please
Old 04-05-2012, 05:07 PM   #5
It is the rectangular box circled in the picture below:
Old 04-07-2012, 09:09 AM   #6
Nas_RS
Vitz_RS
i check mine today, there is no box like in the picture, there only the small box
Old 04-07-2012, 09:10 AM   #7
Nas_RS
Vitz_RS
Please find Pics
Old 04-05-2013, 04:22 PM   #8
Nas_RS
Vitz_RS
does anybody know how to solve? thx
Old 04-05-2013, 04:56 PM   #9
I now see why yours lacks the evaporative canister.
Here is the system on yours:
Here is what ours looks like:
I would suggest disconnecting the charcoal filter (the little box on the rear left of your picture above) and verifying that it is not fuel or water saturated.
Old 04-06-2013, 06:37 AM   #10
Nas_RS
Vitz_RS
Hello Scott, do you where around it will be, i am not able to locate it from the diagram
Old 04-06-2013, 07:28 AM   #11
Nas_RS
Vitz_RS
I am able to remove the little box, how to open it, please
Old 04-06-2013, 08:10 AM   #12
Nas_RS
Vitz_RS
Scott i need this box to be replace, can you get me one, email naseemkhoodaruth@gmail.com
Old 04-06-2013, 12:06 PM   #13
Astroman
Modded Moderator
Astroman's Avatar
Moved this thread to the maintenance section.
Old 04-09-2013, 12:20 AM   #14
YarisSedan
Drives: 08 Yaris Sedan
Its most likely a bad fuel tank pressure sensor. I believe its a 2 wire sensor thats located somewhere on top of the gas tank thats pressed in. Never changed one on a yaris but typically thats the most common for that code. That or a stuck closed canister purge valve.
Old 04-09-2013, 12:32 AM   #15
The Yaris doesn't have a fuel tank pressure sensor and the OP's JDM Vitz lacks a canister purge valve, like USDM Yaris have.
