Old 05-02-2010, 08:57 PM   #1
2002vitz
Drives: 2002 Vitz
2002 Japanese Imported Vitz – Standard Radio Question
Hi Guys, I am new to the forum and hoping somebody here can help me. I recently purchased a 2002 toyota vitz which comes with the standard built in Toyota radio/tape/cd. The car is an import so the radio does not work as is.
The Radio has the following model number on it.
Pioneer FH-M9217ZT
The radio is pretty much OK but I need to install a band expander to pick up the missing channels.
1) Does somebody know where I can get an English manual for the radio?
2) A wiring diagram would be good. I am trying to hook up the positive wire from the band expander but working under that dash is not easy. Where is the easiest place to hook up the positive? I have not been able to get to the cigarette lighter which was my first choice but I can piggy back on the wire's going into the radio itself. These are easier to get to and it does not require me to take apart most of the dash, Which of the wires going into the radio is the positive? There are 2 sets of plugs.
Thanks Guys
Hopefully I can contribute sometime too.
2002vitz is offline   Reply With Quote
Old 05-02-2010, 09:49 PM   #2
Here's the radio wiring diagram for the TMC made 2002:
Radio 2002 TMC.pdf
Old 05-05-2010, 10:55 PM   #3
2002vitz
Drives: 2002 Vitz
Attachment 33659
Thanks for that CTScott
Anybody know where I can get a manual for the radio?
Also, where is the easiest place under the dash to connect a positive wire for the band expander?
Was thinking the car lighter but its so difficult getting under there.
Old 11-15-2011, 04:32 PM   #4
Manufacturer
Drives: Toyota
FM Band expander must be connected to a Accessory +12 Volts source only! Do not connect the unit to a permanent +12 Volts source!
If you need best quality FM Band expander - FM Japanese Radio Converter buy from me without paying a middle man.
Kind Regards
Odyssey
+642102916570Mobile
http://bandexpanders.comze.com/1_2_Products.html
Manufacturer is offline   Reply With Quote
Old 04-09-2013, 12:18 AM   #5
2002vitz
Drives: 2002 Vitz
Hey guys. I have decided to replace the radio in this car but am unable to find a radio fitting kit anywhere.
Here is what the radio looks like currently:
As you can see its not possible to simply change it with a standard better radio.
Some of the other Vitz/echo models use a bracket like this.
Anybody know where I can get one? I dont mind ordering from overseas but have not been able to find these things anywhere in New Zealanad.
Otherwise any other suggestions would be appriciated.
Cheers
Old 04-09-2013, 12:42 AM   #6
The part number is 55406-52011-B2 and they are about $50 for a new one.
Old 04-17-2013, 10:13 PM   #7
2002vitz
Drives: 2002 Vitz
Cheers for that.
Old 05-29-2013, 10:06 PM   #8
2002vitz
Drives: 2002 Vitz
Just an update for anybody else that ever wants to change their radio in a 2002 Toyota Vitz/Yaris/Platz or Echo
I purchase one of these from ebay for GBP 12.95.
The hardest part of the job was figuring how to remove the old cigarette lighter (12Volt supply). Eventually it came out.
The new facia just clips in replacing the entire section.
New Radio is a Pioneer Mechless MVH155UI. JB-HIFI is currently running a special for $70.40 delivered. Ends 4 June 2013.
Tags
2002, echo, fh-m9217zt, pioneer, vitz
Adding a radio...dashkit question 47_MasoN_47 In Car Entertainment + Electronics (audio / video / alarm) 3 09-10-2009 01:01 PM
Car Radio for 2008 Yaris Sedan Question Chubbster In Car Entertainment + Electronics (audio / video / alarm) 20 08-18-2009 05:38 PM
Question about Radio Install kits for double din radios kustom play In Car Entertainment + Electronics (audio / video / alarm) 3 06-03-2009 12:21 AM
Stupid question about installing a radio fmicle In Car Entertainment + Electronics (audio / video / alarm) 6 05-26-2007 05:20 PM
Quick electronic question. radio (grounded) Blenjar In Car Entertainment + Electronics (audio / video / alarm) 15 05-17-2007 10:09 AM
