Old 04-12-2013, 03:21 PM   #73
misterwolfe
What is a clutch?
Drives: 2007 Yaris HB
Send a message via AIM to misterwolfe
Yes. Below is a link to my DIY for 06-11 Yaris. I carry all of the part required if you are interested in installing it:
http://www.yarisworld.com/forums/showthread.php?t=33750
Thank you! Though with requiring to wire up my steering column, that may be my roadblock. Will look into this. (I am colorblind, and at the mercy of my father doing these for me.)
If it is relatively easy, I'll totally buy an entire kit from ya. Also, hoping for keyless entry soon too!
misterwolfe is offline   Reply With Quote
Old 04-30-2013, 09:55 PM   #74
Licky
Drives: yaris
Hi everyone, I am new here, and from australia.
I have a Yaris YR 5 door (base model, 1.3 manual)
I have "acquired" a OEM cruise control stalk and cable, I can fit it into the steering wheel no worries, the cruise light comes on, though can not set the speed. Would this be because of the clutch switch?. I have tried Toyota, and they werent really much help. Though they did come back with a $90 part. I do have to push the clutch in to start the vehicle to begin with though, so i would assume it would already have one?.
Could someone please shed some light for me?
THanks.
Licky is offline   Reply With Quote
Old 04-30-2013, 10:09 PM   #75
THanks.
There are two clutch switches on a manual transmission Yaris. The pre-installed on is the push the clutch to the floor to start the car one. The one you have to add for cruise control works the opposite way. It replaces the stopper bolt that the clutch arm rests against (when your foot is not on it) and it signals the ECM when you barely touch the clutch pedal (to prevent the revving that would occur if the clutch was pressed when cruise was applying throttle).
Old 07-05-2013, 09:09 AM   #76
geoded
geoded's Avatar
Drives: Yaris MY2012 - 1ND-TV
wiring diagrams
[QUOTE=CTScott;615019]I recently obtained the wiring diagrams for the 2012 Yaris. Much of the wiring and connectors remain the same as the second generation Yaris. This is the case for cruise control, so 2012 Yaris owners can DIY cruise control using the same OEM stalk.
For the 2012 the wiring is the same as that of the 2009-2011 Yaris, where the wiring from the ECM to the steering column is (theoretically) there. Also, the 2012 Yaris has the cruise control "On" and "Set" indicators built into the instrument cluster.
CTScott Hello, if you have wiring diagrams for the 2012 Yaris, you help us and us with them? Please much.
geoded is offline   Reply With Quote
Old 07-06-2013, 05:46 AM   #77
geoded
geoded's Avatar
Which is code oem cruise control stalk for Toyota Yaris ?
Old 07-06-2013, 09:56 AM   #78
geoded
geoded's Avatar
Code for cruise control stalk toyota yaris is 84632-34011 or 84632-0F010, can you help me ?
Old 07-06-2013, 03:06 PM   #79
geoded
geoded's Avatar
anyone can help me?
Old 07-31-2013, 06:48 AM   #80
geoded
geoded's Avatar
Hello everyone. I bought the pieces of picture 1, I installed according to picture 2 3.4, but the result was negative, to me does not work. I 1ND-TV engine, 1.4 D4D 66kW respectively. Can someone help me? You need to do something else than I did? Have to change terminals 1 and 2 of the 4-pin connector in the 10 pin?
Old 07-31-2013, 07:50 AM   #81
You have everything installed in the proper place, but according to the wiring diagrams the 1ND-TV Yaris does not support cruise control.
Check the connector on the other end of the spiral cable, which is located under the cover for the lower part of the steering column. The question is if the two wires are present there that would connect to the cruise control stalk wires under the airbag.
Old 07-31-2013, 08:33 AM   #82
geoded
geoded's Avatar
I understand the need to loosen the screw from the one in picture 1 and picture 2, but do not know exactly what wires need to see, you have a picture of what should I see there?
Old 07-31-2013, 08:37 AM   #83
geoded
geoded's Avatar
Is it worth trying to move to Terminal 1 and 2 of the 4-pin connector at position 1 and 2 of the 10-pin connector? or is in vain? still will not go anything? The blue wire is the ground wire and do not know where to put it if put in place the terminal 1 of the 4-pin plug.
Old 07-31-2013, 10:17 AM   #84
No. Where you have the connector is correct for ones that are cruise control equipped.
Old 07-31-2013, 10:21 AM   #85
I am looking for the connector on the left in the photo below. You will remove the two screws behind the steering wheel and the one by the tilt lever to remove the lower cover.
Old 07-31-2013, 11:27 AM   #86
geoded
geoded's Avatar
Connector 1? or two, or three ...... ? I think the connector one you mean but I want to call you. Right?
Old 07-31-2013, 11:34 AM   #87
geoded
geoded's Avatar
You do not have the wiring diagram for 1.4 d4d? Although I know that the same engine Auris 1.4 D4D has cruise control, I hope someone will hear us and we may find a solution in the future, I just have to have patience.
Old 07-31-2013, 12:24 PM   #88
It is connector 1 that we need to look at. I do have the D4D wiring diagrams, where the "engine control" one does not show cruise control, whereby the wiring diagrams for the 1.33L gas engine does. I don't have the wiring diagrams for the Auris, but I do see in the parts catalog that it uses a different ECM.
Old 07-31-2013, 12:48 PM   #89
geoded
geoded's Avatar
Thanks a lot for your help CTScott.
Old 08-02-2013, 12:29 PM   #90
fredansandy
Drives: 2012 Yaris
CTScott,
I am new to this forum. My daughter in Indiana just purchased a 2012 Yaris Sedan without cruise control. I noticed from the pictures she sent, that the cluster is mounted in the center of the dash vs behing the steering wheel as I am seeing in the pictures in this thread. I am guessing that Toyota did a mid-year refresh of the vehicle in 2012 and that she has the older version.
I have two questions...
1) Can I add OEM cruise to her car using your instructions?
2) If so, which directions do I use. The ones for 2009-2011 or the ones for 2012?
I have added OEM cruise to another daughters 2010 Cobalt. This looks much easier than that.
Thanks,
Fred
fredansandy is offline   Reply With Quote
cruise control. 2012
