Old 10-11-2012, 08:22 AM   #415
ciscobear
Drives: Toyota Belta
Originally Posted by GianniVRS View Post
Does this (Window switch problem) concern the JDM version VITZ or just the EU / USA markets?
Recall of six models Vitz and Belta Notification number 3036
, October 11 start date recall
For the vehicle part of the six models Vitz and Belta, I reported to the Ministry of Land, Infrastructure and Transport following the recall of content on 10 October 2012.
Illustration where improvement
One. Status of the problem
Some of the power window switch on the driver's door, grease for lubrication of the switch is not uniformly applied, that the lubricity is deteriorated grease is carbonized by (spark) arc generated in the contact portion at the time of switch operation have. Therefore, there is a possibility that the sliding switch is deteriorated, and the contact malfunction worn early.
Further, when applied to a commercial lubricant like trying to improve the sliding switch failure may cause the switch to melting.
2. The contents of improvement
And replace it with a switch board coated with a heat-resisting grease, about what to check all vehicles, the power window switches, malfunction is confirmed, but otherwise, grease the heat resistance at the contact.
Also, about what the inspection above, was applied to the heat-resistant grease, Then, if malfunction occurs, we replace the power window switch.
http://toyota.jp/recall/2012/1010_4.html
Check the page to see if your car is affected.
ciscobear is offline   Reply With Quote
Old 12-08-2012, 01:28 PM   #416
charles nelson
Drives: red Liftback
My dealer said that I would be receiving a recall letter in about two weeks. It has now been over six weeks. Has Toyota decided not to inform owners about the recall?
Update...of course, I just received the recall letter...6 weeks after my dealer informed me about it.
charles nelson is offline   Reply With Quote
Old 04-20-2013, 05:49 PM   #417
yarisitis
yarisitis's Avatar
Drives: 2008 Yaris LB
For those who have had their Yaris' fixed for the power window switch recall, what were your experiences? Did you only take your car in when you noticed the window exhibiting the "notchy/sticky" operation or did you take it in regardless of that? I'm assuming they have to remove the door side panel to get to the internal window parts? Did the service people do a good job, did they mess anything up or break anything in the process?
I want to take my car in for this recall but I'm a little hesitant as to if it's really necessary and also I'm scared they might end up messing something up in the process.
yarisitis is offline   Reply With Quote
Old 04-20-2013, 08:05 PM   #418
edmscan
edmscan's Avatar
Drives: 2020 Corolla
I took my car in ... they fixed the problem (even though I never experienced any problems in the past with my windows), and you would have never known that they did anything. Everything was perfectly done.
edmscan is offline   Reply With Quote
Old 04-20-2013, 09:09 PM   #419
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by edmscan View Post
...and you would have never known that they did anything.
Maybe they didn't...
(sorry, couldn't resist )
Old 07-05-2013, 10:21 AM   #420
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
New recall July 2013
I haven't seen no posts on this so I'll put it in the right spot.
http://pressroom.toyota.com/releases...aris+july2.htm
http://www.toyota.com/owners/web/pag...ources/recalls
http://www.reuters.com/article/2013/...0F91AT20130703
http://www.cnbc.com/id/100862449
Killchain is offline   Reply With Quote
Old 07-09-2013, 07:44 AM   #421
LugNut
Drives: 2007 2DR Liftback
Finally got it done
I took my 2007 liftback in for the window switch service recently, and it went very quickly. The switch did seem a bit notchy before, but I don't know if they just greased it or replaced it.
On the rusty lower front suspension bolts, I asked if they had seen any that have failed here. They said no, and they had no replacements in stock. I see the bolts for about $4 each on various websites, so I may pick them up and replace them anyway in the future.
LugNut is offline   Reply With Quote
Old 11-07-2013, 12:11 AM   #422
2012 YarisSE
Drives: NCP131
SPECIAL SERVICE CAMPAIGN # 212
REPLACE THE ELECTRIC POWER STEERING
CONTROL MODULE
Models:
2012 MODEL YEAR YARIS HATCHBACK
AFFECTED VEHICLES:
JTDKTUD3XCD500157
JTDJTUD39CD500159
JTDJTUD39CD500162
JTDKTUD38CD500111
JTDKTUD35CD500115
JTDKTUD32CD500153
JTDKTUD32CD500170
JTDKTUD37CD500178
JTDKTUD31CD500192
JTDKTUD39CD500196
JTDKTUD35CD500227
JTDKTUD38CD500237
JTDKTUD30CD500183
JTDKTUD36CD500222
JTDKTUD37CD500231
Production Period
Late May, 2011 through Late August, 2011
2012 YarisSE is offline   Reply With Quote
Old 04-09-2014, 03:19 PM   #423
smofskra
smofskra's Avatar
Drives: 08 Flint Mica Sedan
Send a message via MSN to smofskra Send a message via Yahoo to smofskra
A new recall including Yaris model years 2006-2010 http://www.latimes.com/business/auto...#axzz2yPvzWRIG
"Chrome wont get you home"
smofskra is offline   Reply With Quote
Old 04-16-2014, 01:23 AM   #424
jsambell
Drives: 2003 3dr Hatch Silver
Seat recall also applies in Australia:
http://www.recalls.gov.au/content/in...itemId/1057693
jsambell is offline   Reply With Quote
Old 04-20-2014, 10:40 PM   #425
LilyOfTheYaris
LilyOfTheYaris's Avatar
Drives: 2007 Yaris
This is what I got on my Toyota Owner's profile...hope the picture shows up I'm attaching it. Apparently, Toyota is working on a solution in the near future.
LilyOfTheYaris is offline   Reply With Quote
Old 05-16-2014, 12:02 AM   #426
MiSFiTx87
MiSFiTx87's Avatar
Drives: CS1
Anyone received their recall letters yet? I got one but I have to pick it up on the weekend and head to a local toyota
MiSFiTx87 is offline   Reply With Quote
Old 05-16-2014, 05:37 AM   #427
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
I just got my Seat Track recall letter
Check out my Build thread:
Old 05-16-2014, 06:44 AM   #428
I received the spiral cable one for my 09 yesterday.
Old 05-16-2014, 11:39 AM   #429
Steveh27
Drives: 2010 3dr hatchback auto red
me too
I got the spiral cable one for my 2010 yesterday. Wonder when the other arrives & how long it'll take them to come up with a repair & tell us to bring them in?
Steveh27 is offline   Reply With Quote
Old 05-16-2014, 11:53 AM   #430
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I still haven't heard shit and I checked the website. My car will receive both. This is a real concern too since I will be cannibalizing another seat to mount my racing seat to.
sent from my m-o-b-i-l-e
Old 05-16-2014, 12:36 PM   #431
I received the 3 door seat track notice for my 08 today.
Old 05-16-2014, 03:43 PM   #432
SKurj
Drives: 09 Yaris 3dr HB, BRZ
I got that notice last week for my 09 3dr as well, but it sounds like its just a notice and they haven't got the fix yet.. or I read bad..
SKurj is offline   Reply With Quote
Response from Toyota on my special order drdavidr4u New YARIS Purchase Forum 14 04-27-2010 08:59 PM
Yaris In Forza 3 whooppee777 Off-topic / Other Cars / Everything else Discussions 61 04-03-2010 04:36 PM
Toyota Temporarily Suspends Sales of Selected Vehicles redglare45 Off-topic / Other Cars / Everything else Discussions 0 01-26-2010 06:33 PM
Toyota Delays Buckethead General Yaris / Vitz Discussion 3 08-26-2006 03:16 AM
Toyota recalls vehicles over faulty engine Lizardboy General Yaris / Vitz Discussion 1 07-18-2006 07:07 PM
