Old 04-17-2013, 05:15 PM   #1
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Greddy speed limit cut installation
So I bought one of those Greddy speed limit cut boxes. Planning to wire it in at the same time I proper solder all my boost wires in. Seems pretty easy but it claims in the instructions that you can use one of the wires to control boost by what speed you're going. This was intriguing because I've been looking for a way to get boost to work while in cruise control. I'm just not certain how to make this work with the Blitz, or if it even will.
Any advice welcome.
Old 04-17-2013, 08:11 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
just be sure that you know that your cruise control will not work with the cut in place so you may want to plan for that in your installation if you like to use it.
Old 04-24-2013, 12:33 AM   #3
47_MasoN_47
Ugh, why not?
Old 04-24-2013, 01:49 AM   #4
How would you control boost on the Blitz?
Old 04-24-2013, 11:18 AM   #5
fnkngrv
fnkngrv's Avatar
Originally Posted by 47_MasoN_47 View Post
Ugh, why not?
It has to do with how the module fools the ECU into thinking that you are going a certain speed we (Scott and I) believe. I hooked mine up with quick connects that way I can remove/install it with ease since there is no need for it on public roadways.
Old 04-24-2013, 01:09 PM   #6
47_MasoN_47
Ah, well yeah I guess that makes sense. Well I guess I'll dump the idea of using it to control the Blitz then as it wouldn't help anything anyway.
I was planning to install mine in a similar fashion. Do you think it would be ok to install a couple of switches in there so that (when the car is off of course) you could just flip a switch to turn the speed limit cut on or off?
Old 05-02-2013, 09:04 AM   #7
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ yeah you just need a SPDT switch if it's only one wire.
Old 05-02-2013, 09:48 PM   #8
fnkngrv
fnkngrv's Avatar
I had talked about it with Scott at one point, but forgot what the answer is.
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 10:40 AM
Highway minimum speed limit bentjazz Fuel Economy Forum 33 04-12-2011 06:38 PM
Elusive Greddy Ti-C? RShatchback Performance Modifications 36 06-05-2007 05:11 PM
