Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 05-02-2013, 07:03 AM   #1
swidd
Drives: Yaris HB
WTB: Fog light switch from the Micro Image fog light kit
Hi,
if anyone didn't use their fog light switch, I'm in need of one, after breaking it when doing the install.
http://i.imgur.com/klEF23p.jpg
http://i.imgur.com/9aKY3nM.jpg
http://i.imgur.com/H9zFvGi.jpg
Name your price and shipping to 35213/Alabama.
Of course if Garm will sell me another one, that'd be great too :-)
swidd is offline   Reply With Quote
Old 05-02-2013, 12:47 PM   #2
Happy to send you another one. email me at mcroimg@gmail.com
Old 05-02-2013, 09:58 PM   #3
swidd
Drives: Yaris HB
Thanks, but ctscott beat you to it.
Old 05-03-2013, 01:21 AM   #4
^ He sent you one of mine. Cool!
Old 05-11-2013, 02:38 AM   #5
swidd
Drives: Yaris HB
Hey Cali, check out where those stickers you sent me went:
http://i.imgur.com/j7iwJFk.jpg
http://i.imgur.com/x2XOOZt.jpg
http://i.imgur.com/iS9pZH0.jpg
http://i.imgur.com/xAEqUtb.jpg
Old 05-11-2013, 02:46 AM   #6
SWEET! Can I post one of those on our Facebook page?
Old 05-11-2013, 03:28 PM   #7
swidd
Drives: Yaris HB
Yeah, spread away.
Old 05-14-2013, 01:32 PM   #8
swidd
Drives: Yaris HB
Oy, how exactly do I open the switch to snip the resistor?
CTScott, did you snip a resistor?
Right now I've installed the kit, but the fog lights do not turn on. However the switch lights up, even when the key is out of the ignition, ie hot bus.
Seeing as I broke the previous switch without even getting it open, there must be a trick to opening it that I don't understand.
Old 05-14-2013, 01:53 PM   #9
The one I shipped I pre-snipped, so you should just plug her in.
If the light is always on and the switch does not turn the fogs on, it sounds like you have a wiring issue. Post a pic of where the switch wires are connected to.
Old 05-14-2013, 07:49 PM   #10
swidd
Drives: Yaris HB
Album: http://imgur.com/gallery/ptKzH/new
Most relevant: http://i.imgur.com/1ycFWpo.jpg
I followed the instructions that are on the MI website under the fog light product description. The top document anyway.
More: http://i.imgur.com/1hwHsAB.jpg
Noticed something that is relevant: http://i.imgur.com/GxiVvWN.jpg The green wire is effectively plugged into nothing. There are no pins on the D4 steering column terminal for where the green wire plugs in.
Old 05-14-2013, 08:06 PM   #11
Noticed something that is relevant: http://i.imgur.com/GxiVvWN.jpg The green wire is effectively plugged into nothing. There are no pins on the D14 steering column terminal for where the green wire plugs in.
OK - You followed "the other" set of instructions for the Micro Image kit. This is my version, which is the correct version for the modified switch:
http://www.microimageonline.com/down...h%20Wiring.pdf
Old 05-14-2013, 08:10 PM   #12
swidd
Drives: Yaris HB
So for option 6 b, fog lights on with low, high and park:
I will be plugging both wires from the switch into 13 and 3? But 3 doesn't connect to anything...
Am I supposed to just remove the wires that are in there already, and leave them hanging unconnected?
Old 05-14-2013, 08:17 PM   #13
We only have one set of instructions posted, for the aftermarket round switch. They would not be correct for the rectangular switch we used to include (a big reason was because of the modification needed on the switch)
Old 05-14-2013, 08:48 PM   #14
Garm,
He was following the original kit instructions (the set prior to mine).
Old 05-14-2013, 08:50 PM   #15
Into the original Yellow wire 3 (you will put it back as it was when you started and then tap one of the switch wires to it and the other to the wire in pin 13).
Old 05-14-2013, 11:02 PM   #16
swidd
Drives: Yaris HB
So I have to remove the ends of the switch's wire and just tap 3 and 13... Okay :-)
I really didn't understand that from reading the manual. I'm not a smart man :-/
Old 05-14-2013, 11:38 PM   #17
There was always much confusion on that. It means that you need to split the switch's harness all the way to the switch, so that there are four completely separate wires, and then you need to extend some of them to reach where they need to go.
Old 05-15-2013, 12:38 AM   #18
swidd
Drives: Yaris HB
Now you just confused me even more. There's three wires coming out of the switch socket.
Black (which I grounded)
Green (in picture)
Red (in picture).
Where does each go? If I want to ignore the switch light and just have functional fog lights, can I stick with the instructions in 6(b) and just merge green and red to 3 and 13? And leave black grounded?
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 11:42 AM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 05:11 PM
Bulb Size For After Market Fog Light Kit razzorjet2 DIY / Maintenance / Service 1 04-10-2007 03:15 PM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 04:09 AM
question on Fog light clfile Cosmetic Modifications (Exterior/Interior) 6 11-09-2006 08:11 PM
