Old 05-10-2013, 02:42 AM   #1
cnister1
Drives: n/a
Question yaris engine swapped into a old skool KP61 possible?
Hello guys!
I don't own a yaris buuuuut I'm interested in trying to swap the Yaris engine into my KP61 starlet. I know I know that the most popular swaps are 4ag or 13b rotary but I kinda wanted to stay as close as possible to it's 1.3L roots! And so the yaris is what I have in mind..
My questions are many but here's a few!
1. What would I have to modify on the engine to make it from fwd to rwd?
2. Anyone know of a rwd transmission that would be a straight bolt-on?
3. Even better has anyone performed this on any other car from fwd to rwd?
My Yaris gurus! I seek your knowledge and guidance! The Yaris engine would be an awesome upgrade if you consider that the original 4K-C engine only made:
The 1981 and 1982 California-spec 4K-C produced 58 hp (43 kW) at 5200 RPM and 67 lb·ft (90 Nm) at 3600 RPM.
cnister1 is offline   Reply With Quote
Old 05-13-2013, 07:05 PM   #2
There is a dedicated thread for motor swap discussions:
http://www.yarisworld.com/forums/showthread.php?t=15242
Old 05-13-2013, 10:18 PM   #3
cnister1
Drives: n/a
I saw it but it's more geared towards swaps for the yaris! I wanna swap the yaris engine onto my starlet!
I'll repost and see what happens!
Old 05-14-2013, 12:16 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
The 4AGE would be the easiest, most affordable, least modifications, most parts available, etc.. Besides, the 2NZFE is 1.5L, closer to a 1.6L 4AGE than a 1.3L 4KC. How about a 1.2L 3KC? That's closer to the Starlet roots. Don't mean to discourage you but trying to install a 2NZFE into your Starlet will require a lot of $$$ to modify it to fit into you vehicle. Good luck if you ever even attempt it.
Old 05-14-2013, 09:17 AM   #5
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
You could do it with custom mounting and if you take the transmission apart and weld the diff you could use it. You'd just need to make a cover for the open side and a custom driveshaft.
Toyota Yaris Engine Map wariss Performance Modifications 5 03-15-2009 01:21 PM
