![]() ![]() Drives: Toyota Vitz 2007 facelift Join Date: Jan 2012
CVT drain / refill - Yaris 2007
Hi,
My Yaris sedan has completed about 47,000 kms and I'm planning to replace the CVT fluid in the near future. Do I need to also clean up the filter inside or should a simple drain / refill suffice with removing the drain bolt and the drain tube? Frankly, speaking I do not want to open up the sump but if it has to be done then will do it as that would entail replacing the gasket, drain tube o-ring etc. Would appreciate some suggestions/advice from those who have done this. Thanks Tyrone |
Da Uncle
Drives: 2008 Toyota Yaris Sedan Join Date: Oct 2008
Hi,
its nice to see somone with a CVT Yaris. I thought it only sells in Japan. is it Sedan or Hatchback? and the engine 1.3 or 1.5? 4WD too? I might not be of help in changing the oil but I am curious about the Car
#3 | |
![]() Yes its available worldwide with different names. Here its called a Belta. Its a Sedan 1.0 L Two wheel drive. |
I doubt anyone is this country has ever seen a CVT in a Yaris or knows about changing the oil.
Except CTScott....
![]() Drives: Toyota Vitz 2010 Join Date: May 2013
Im also seeking for help.
I cant find the cvt oil or how to check it. My car came from Japan and has Super CVT-i |
What does the owners manual say to do?
Here's a link to an article that I posted a while back on the Micro Image forum on how to change the fluid in a CVT:
http://www.microimageonline.com/foru...T-Fluid-Change
Until the iQ showed up in the US the CVT, as far as I know, was not offered on a Toyota here.
I wonder how they hold up compared to a regular automatic? On a scooter with a CVT the belt will need changing at intervals that vary with the rider and usage the bike gets.
#10 | |
Anyone????
The CVT doesn't have a filter, but it does have magnets on the floor of the pan.
#14 |
I wouldn't drop the pan just to clean the magnets, if the gasket is not easy to come by. They can hold quite a bit of shavings.
#15 |
That's good to hear CT Scott. Since I'm doing a flush at 50,000 km and the next will be done at 100,000 km so just wanna make sure that a simple drain refill will be fine and wanted your input as our conditions here are hot and dusty.
#16 |
CT Scott can you help identify this port
While we're on the subject of the CVT flush for the VItz (K410) transmission, I'm attaching a pic of the port that many have used to refill the CVT fluid. Can you identify this port?
Vitz Filler hole1.jpg |
#17 |
It is under the oval shaped black metal piece in the left picture.
#18 | |
http://www.microimageonline.com/foru...T-Fluid-Change |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| TSB's | WD-40 | General Yaris / Vitz Discussion | 27 | 06-06-2007 01:11 AM |
