New bike - electric!
Always tinkering with some new idea. This is a pretty fun ride. 500w 36v 12aH, FWD electric bike. Thanks to John Kuchta for the excellent fabrication work.
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
Lazy! Lol
Does it have regenerative braking :-P Looks pretty sweet all joking aside.
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
Given that the motors are directly in the wheel it looks like it should be quite easy to make some sort of diode bridge and redirect the counter electromotive force generated on negative acceleration back to the battery through an AC/DC converter(might be a little redundant since the bridge can do the same thing) and recharge the battery.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#4 | |
um....i already gave a brief explanation of how to do it so yea, now you have to figure out the details :P
^ Thanks
Modded Moderator
Sweet
^ Coaster brake.
Time for some super caps (like the 4 lb pack I am running in Crashy2, in place of the OEM battery), instead of the SLA for some serious weight savings, and the easy ability to do regenerative braking.
0-60 in slow
Nah pickup a bunch LiPOFe4 cells and make a nice battery pack.
I've been tempted to make a battery pack out of a bunch of leftover A123 cells I have. Nothing like 100+ cells sitting around to make you think of the possibilities. Garm if you cut the power to the electric motor it should work as a pretty decent generator(DC) and a semi functional brake as well. |
The kit will support up to 60v, which means I'm just getting started at 36v. Might try bumping it up to 48v first.
Range extension will be a future project, right now 20 miles gets me back and forth to work 3 days in a row without charging. Not bad. And pedaling extends the range greatly. Fun toy!
what is the generating out put of the electric motor?
#13 | |
post #1:
i see, that should be enough to daily commute as long as you don't have any steep hills, then it gets all leg power. 12aH seems kind of low for rapid recharging, might have to amplify the out put to get the best benefit out of it.
This for getting to work on time even when your a day late.
play every day
![]() Hey Garm, ![]() Cool bike! |
^ 26" wheels with "Thick Brick" tires. This one is fine for my 3 mile commute to work. I have a few small things to do (rear rack, etc.)
My next one will be an ultralight carbon eBike.
| 2012 Ford Focus ELECTRIC | Kal-El | Off-topic / Other Cars / Everything else Discussions | 11 | 02-11-2011 11:34 AM |
| Yaris hauling dirt bike? | kustom play | General Yaris / Vitz Discussion | 13 | 05-17-2010 03:18 PM |
| Trunk Mount - Saris Bones 2 Bike Rack & New MT Bike | kuyachris84 | Photo-Video-Media Gallery | 11 | 07-14-2009 12:39 PM |
