Old 06-16-2013, 09:07 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
YarisSedans Ongoing Modification Thread
So I decided to start a thread to store all my mods that I currently have and on going as I have many more planned over the course of the next few months.
Current Performance and Suspension Mods
TRD Exhaust
TRD Swaybar
TRD Springs
Tokiko Shocks
Tannabe Front Strut Brace
Ultra Racing Rear Strut Brace
Megan Racing Front and Mid Lower Braces
Nonstop Tuning Pulley Set
Nitto Torque Dampener
Weapon R Electronic Throttle Controller
Konig Helium Rims
Cosmetic Mods
Carbon fiber engine cover
Carbon fiber ebrake handle
Black chrome/carbon fiber front and rear emblems
Color matched rear trunk trim (used to be chrome)
Rear trunk lip spoiler
S Body kit
Black chrome headlight tint
Rear tail light tint
Rear tail light chrome bulbs
Front Fog Lights with tint
Upcoming/waiting to be installed mods
Corolla Throttle body
powergrid swaybar links
Silicon radiator hoses
Old 06-16-2013, 09:10 PM   #2
YarisSedan
So my current mod I did for today was black chrome tint my headlights I was going to go with a strait tint film but I still wanted to retain the headlights reflectiveness from the chrome and gave it a rather unique look. It ended up coming out exactly as I envisioned.
This was the product I used it comes in a kit with the black chrome tint and clear coat
Same product I used in my other post for my emblems http://www.yarisworld.com/forums/showthread.php?t=45300
And Here is how it looked before on the stock headlights
And after the black chrome tinting
And this is with the eyelids with black chrome tint
Old 06-16-2013, 09:18 PM   #3
YarisSedan
So here is a side by side comparison you can see how the light reflects of the headlight a little different than if you use just a typical headlight tint film. I went ahead and put only 2 very light coats of the tint and then 4 coats of clear coat. All the pictures I am currently posting the lenses have not been wet sanded and polished yet, I expect them to give a bit more gloss. Since they are clear coated they should be able to take a automotive paint wax to give the lenses even more of a shine as well as UV protection from fading.
When I took the headlights out I noticed there is already a factory spot to mount a HID ballast
So I came up with the idea of using 2 zip ties and some screws and washers to make a proper mount to hold the ballast to the headlight, I was going to use mounting tape but the ballast wasn't a perfect fit and wouldn't stay flat. With the zip ties its easy to remove and replace if my ballast ever burn out down the road so its a less permanent install.
Zip tied the wires along the factory wires for a super clean install looks almost like thast the way it came from the factory.
Since i had my eyelids off I took the time to clear coat them as well
And it turns out good I didnt waste my mounting tape one roll was just barely enough to do my eyelids
Old 06-16-2013, 09:22 PM   #4
YarisSedan
Here are a few more shots later in the day in the shade as well as close up
Old 06-23-2013, 03:50 AM   #5
YarisSedan
Decided to black chrome my head unit to go well with my dash this is how it looked like before
And this is how it turned out
Old 06-23-2013, 03:51 AM   #6
YarisSedan
Also tinted my tail lights as well today. Here is a side by side comparison
Old 06-23-2013, 03:52 AM   #7
YarisSedan
And here they are installed. I think it came out perfect. It has just enough of a toned down shade that it looks almost factory and wont attract cops.
Old 06-23-2013, 03:56 AM   #8
YarisSedan
I also modified my center cap I wasnt a fan of the chrome konig ones and there was nothing available in black so i decided to make my own!
First i had to remove the sticker in the center and it turns out it was covering a hole in the middle, I then fiberglased over it and sanded down the top part lip.
Old 06-23-2013, 04:07 AM   #9
YarisSedan
Ive been tinkering with the idea of converting to a single wiper blade since the passanger side is only a 13 and dosnt do much. I like the style and look of the wipers from the honda civic heres a comparison
Old 06-23-2013, 08:07 AM   #10
Chifte
Chifte's Avatar
Drives: 2012 Yaris
You should definitely do it, I like the single blade that comes with the '12s.
Chifte is offline   Reply With Quote
Old 06-24-2013, 10:28 AM   #11
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
My front lip did the same thing as yours where it sags lower on one side even though the mounting points are even lol
Old 06-30-2013, 06:48 PM   #12
willisjm193
Yoshi 2.0
willisjm193's Avatar
Drives: 2007 Manual Sedan
Did you do your tail lights from the outside, or did you take them apart? I've got the same paint you have and I like the outcome on your lights.
willisjm193 is offline   Reply With Quote
Old 06-30-2013, 08:02 PM   #13
YarisSedan
I painted them from the outside
Old 08-17-2013, 07:47 PM   #14
MyzticZ3r0
What paint did you end up using for your taillights? VHT nightshade? I am comtemplating doing this myself.
MyzticZ3r0 is offline   Reply With Quote
Old 10-17-2013, 04:39 AM   #15
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
keep up the good work ! u got a fan here
BLOODY_STONE is offline   Reply With Quote
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 02:58 PM
H3LlIoN's ongoing audio thread H3LlIoN In Car Entertainment + Electronics (audio / video / alarm) 6 11-08-2009 01:20 AM
