Old 07-29-2013, 09:40 PM   #127
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
White lithium grease spray was only $2.47 a can at Walmart. 30 seconds of my time and my squeak is gone! :) Kind of awkward due to the radiator hose being in the way.
DebbyM46227 is offline   Reply With Quote
Old 08-16-2013, 05:22 PM   #128
bryanhoule
Drives: 2007 Toyota Yaris MT LB 2-door
I had the same squeak. I'm at about 83,000 miles. If you like instant gratification, this is a good one! WOW! Problem fixed the INSTANT i sprayed the part highlighted with the yellow circle and two yellow dots. WAY smoother shifting now, way less friction!. Huge difference (and I just changed my manual transmission oil to the Redline MT-90 stuff, and that helped slightly but was nothing compared to lubing these shifting linkages). I used Johnsen's Multi-Purpose Silicone Lubricant. Time will tell how long it lasts. If it lasts a long time, good, if not, next time I'm going to use a White Lithium Grease Spray. I removed the intake air filter box to make the access easier, but it's not completely necessary. Also, while my friend moved the stick through the gears, I sprayed all the moving parts, not just the "yellow circle with two dots" part. Thanks guys! This is a great forum!
bryanhoule is offline   Reply With Quote
Old 08-16-2013, 08:26 PM   #129
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
I sprayed lithium grease on the linkage with great result the squeak disappeared.
But is it a sign that there's something wrong with the linkage? Like it needs to be replaced? because it's worn or something etc.
My Yari is going great i'm happy to report it's an 07, 3-door hatch, 1.5 ltr engine.It's done 155 556 km and it's still going and keeps going. Touch wood!
I sprayed the linkage added red line mt 90 along with nulon gearbox treatment. I changed the plugs, air filter, oil filter and of course did regular engine oil changes using full synthetic.
Had wheel alignment and it's going well. I feel a bit of an improvement to the way it's running. Touch wood hoping it continues.
Next in line is front brake pad change :)
Old 08-21-2013, 04:11 PM   #130
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
Fixed my squeek with this as well.. first tried the silicone spray.. lasted about 2 weeks.. came back with lithium grease the second time.. been squeek free for a couple months now. :)
CueBall is offline   Reply With Quote
Old 08-21-2013, 10:07 PM   #131
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yeah I was also using silicone for this, but it turns out that stuff only works while its viscosity is just right... After that it ends up making things worse, according to the mechanic.
Old 09-19-2013, 09:18 PM   #132
wilbrod
Drives: Yaris 2008 Hatchback
Thanks. I bought this and was able to spray from the top of the hood area by sliding the can between the radiator and the engine. The I made my way over to the right and had that red spray pipe from the can right inside that gap to spray. Just have to figure out the rear drum squeak now.
If only the girlfriend had not mentioned that squeak to me I may still be living in ignorance.. it is a bliss! :)
wilbrod is offline   Reply With Quote
Old 09-19-2013, 09:20 PM   #133
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Just take the drums off and clean the dust out. The squeak should go away.
Old 10-11-2013, 02:35 AM   #134
Tarryn
Drives: Yaris T3 Sedan a/c
Originally Posted by Lafiro View Post
Hey thanks, but can you post a furthr away picture, and then a closer one please because Im having trouble finding this.
i'm also having trouble with this - did you get the further away pic??
Tarryn is offline   Reply With Quote
Old 10-23-2013, 02:21 PM   #135
aacceerr808
Drives: Yaris 2007 hatchback
Exclamation
Just asked the service advisor at my dealer about lubricating the manual transmission components and he said they never need lubrication because they are all sealed.
Huh?
Funny thing is that a mecanic from a local shop told me the same, he said I'll have to remove the transmision to lub it... . my biggest squick was when I press the clutch pedal, was making a huge squick! The toyota dealer fixed it for 28$.
aacceerr808 is offline   Reply With Quote
Old 10-23-2013, 05:30 PM   #136
TOLMACH
Drives: soarer
Was using silicone lube for two years.. works for two days, then squeaking returns.
Bought this stuff..no-squeaking effect lasted three weeks.. Wow.. today sprayed again
Love it so far
http://www.canadiantire.ca/AST/brows....jsp?locale=en
Old 10-24-2013, 01:34 PM   #137
esse10
Drives: 2009 yaris 2 door
Tranny squeak
Has anybody figure out how to lube the inside transmission clutch fork pivot area? I mean without removing major hardware. red arrows in this picture.
File Type: png toyota-yaris-clutch-parts-components.png (36.8 KB, 303 views)
esse10 is offline   Reply With Quote
Old 10-24-2013, 10:03 PM   #138
Nigel8600
Drives: 2008 Yaris Sedan
I also just oiled the yellow circled section and the problem went away immediately. When I had the car up on my ramps doing the gear oil I gave it an extra shot of spray from underneath too for extra luck. Unfortunately I used silicone spray because it was on sale for 2.50 a can and the white lithium grease spray was 8.99 lol.
Nigel8600 is offline   Reply With Quote
Old 11-02-2013, 01:29 AM   #139
Nigel8600
Soooo, for the record, my silicone spray lasted only 1 day per lube. I sprayed with white lithium that I had to go back to the store and buy 5 days ago and its still not squeaking. Don't waste your time with silicone spray.
Old 09-27-2014, 07:30 AM   #140
Dmonte
Drives: 2007 yaris sedan 4d
Does this also apply to automatic transmissions? Because my car has had a similar squeek for 3 months now ...
Dmonte is offline   Reply With Quote
Old 09-27-2014, 09:40 AM   #141
No. An automatic does not have the mechanism that this thread is discussing.
Old 02-18-2015, 07:58 AM   #142
pightzter
Drives: Vios 2014
hey guys i just registered. im from the philippines and got a 2014 vios which is sort of a sibling of the yaris. found this thread due to a squeak in shifting gears (manual). so anyway thanks to the thread starter my problem got a quick fix instead of lining up in the dealership. i used an ordinary oil lubricant with paintbrush and glazed the joints.
the cause of the squeak, as recalled, was by engine wash. some newbie overdid it using a pressure wash. so a tip out there for squeaking shift gears after an engine wash, the grease from the shift joints inside the engine bay must have absorbed some water and in the process pushed away some of the lunricants.
hope this reply helps.
super thanks to this thread!
pightzter is offline   Reply With Quote
Old 03-28-2015, 02:27 PM   #143
Mikastef
Drives: Yaris
Can this work in an automatic gearbox?
Mikastef is offline   Reply With Quote
Old 03-28-2015, 10:28 PM   #144
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
No, the auto gearbox does not have the clutch lever. Must be something else.
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
