![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
Brakes squeak.
What is causing the feint squeak when i press the brakes? I just noticed it today.What
could it be? It happens when I pull up to a stop and the brakes is fully depressed. |
brakes
If the car is a 2007 and you never done the brakes on it , than it's time. I would remove the rear drums cover and take a little looks and see. Most front wheel drive cars I believe the rear pads wear out faster before the front pads. It could also be the tattle tale on the brake pads, if it has one not all pads have a tattle tale these days.
Modded Moderator
This has been covered quite a bit recently (search!)
![]() For me the solution was this: Removed the rear drums, replaced the brake shoes, both the drums were warped, had them turned, cleaned everything up with brake cleaner, put it back together, squeak gone! Mine is an '07 as well. |
Ok, thanks...
The brakes squeaks when I apply the brakes, but it's also making a humming sound when running. I had this issue with my Nissan before. When the pads ground down, apparently there's an indicator which squeaks/squeals to let us know the pads needs replacing. Well the Yaris isn't squealing like the Nissan i had but there's definitely humming grinding noise from the front wheel area.That's where i think it's coming from or is it the drums at the back?
#5 | |
bearings
#6 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
Thanks,
I'll take all your wonderful advice on board. I do think it's the bearing or brake pads ware. Thanks my fellow Yarisers.
| general service of brakes | TriumphAnt | DIY / Maintenance / Service | 10 | 08-07-2010 02:20 PM |
| Metal scratching from brakes | alt_k1ll3r | DIY / Maintenance / Service | 16 | 02-11-2010 12:04 AM |
| Gearbox/diff squeak, poor engine braking | Kiz | DIY / Maintenance / Service | 8 | 08-01-2009 09:35 AM |
