#19 |
I know, but I've been surprised by the differences in the two before. In theory it shouldn't be any different from platform to platform as long as it has the 1NZ.
#20 |
For those of you complaining about the rough idle, I switched over to Royal Purple 5W30 full synthetic today and it was idling smoother. Just an idea...
#21 |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
well, from what I read in the DIY and what I know of mechanics/electrical, I would say good places to ground are firewall next to the ecu, starter,alternator, the throttlebody(its on the other side of the engine away from the ground on the alternator)or somewhere on the engine close to it,and maybe a couple places on the fenders or chassis.
I am really not sure if it makes the ignition more consistent as everyone says it does, but I know it helps the starter and alternator last longer, and helps if you have a aftermarket stereo. Edit: there is already a DIY in the DIY manual from this site. really all you have to do if you want to make your own, is go down to a local stereo shop and ask if you can have or buy for cheap some of their scraps of wire they have laying around. then make a distribution block from some steel and you are set, all you need is some bolts and metal screws, some light gauge steel, and some 10 gauge+ wire...
#22 | |
#23 | |
Q(','Q)
I could have sworn someone already did a DIY
And here it is
http://www.yarisworld.com/forums/sho...rounding+wires Quote:
#24 | |
#25 |
It wasn't Chris, but yes, someone did.
| Grounding kits | 07WYarisRS | Items for Sale by private party | 55 | 07-28-2007 04:08 AM |
| HID Light Conversion Kits - $170 shipped! | MobileHID | Sponsors Classifieds Area | 120 | 05-02-2007 09:04 PM |
| What's the difference in the Door lock Kits (wire and rod) | mgthompson | General Yaris / Vitz Discussion | 5 | 03-19-2007 01:29 AM |
| Yaris Body Kits???? | SamSam | Cosmetic Modifications (Exterior/Interior) | 23 | 01-15-2007 03:38 PM |
| GROUNDING KIT DIY? | SEaton | DIY / Maintenance / Service | 73 | 10-22-2006 04:03 PM |
