#19 | |
![]() ![]() Drives: 2012 Yaris XR 3DR Join Date: Feb 2012
ALWAYS best to check for yourself though. Can't believe everything you read on the internets and we are dealing with different region specs\builts here. Please report back, if you (or anyone else) do get this working. This will pretty much determine if I go ahead with my project or not. I'm not too comfortable with wiring and I certainly don't want to blow anything up or mess with the warranty in any way.. I retrofitted PDC on one of my previous cars and was on the brink of heart failure the whole time... |
#20 |
@SineWave
Have you installed the camera you mentioned earlier in the thread yet? You don't by any chance have the measurements of what the OEM camera (or the insert that currently fills the gap) should be? I want to figure out if this Crown one will fit. I'm still keen on doing this. |
#21 |
![]() ![]() Drives: Gen3 Yaris ZR Manual Join Date: Jan 2012
I removed my head unit last night, and the connector that is supposed to have the camera signal only has one wire going into it. See the attached image, it's pin 6, park brake sense. This wasn't plugged into the back of the unit, which explains why my system functionality test never showed park brake being on. I tried placing bare wires down the back of the connector, but couldn't get the screen to change to video mode. Video signal went in pin 8, +V went in pin 7 (will check if there is any voltage there or not today) and GND went in pin 16. Video - is supposed to be on pin 15, don't know if I need to short this to GND/pin 16. Will check for continuity.
Does anyone know where to get the pin sockets to populate this connector? |
#22 |
Ouch, and here it thought this would be an easy retrofit...
Perhaps I'll muster up the courage some time this week to take my head unit (mine is different to yours) out and have a look. |
#23 |
The pins actually look like the IDC headers on the backs of IDE hard drives and CD drives. I have a whole bunch of single pin socket leads like these:
![]() Will try again soon. |
#24 |
Drives: Yaris 3rd Generation Join Date: May 2012
Hi,
Could you please tell us if you installed the oem camera succefully ? Thanks a lot for feedback Regards |
#25 |
-YaRiS OwNeR-
Drives: YRS Sedan Join Date: Oct 2008
Hi guys, just wondering if someone had installed a rear camera for Yaris Sedan? Did some research in ebay and still not sure what model of camera that fits in Yaris Sedan.
#26 |
Hi Every body, I have read your comments, and i want to setup a reverse cam in my car, i just want to add this feature!
#27 |
![]() Drives: Yaris 2012 Luna 1.0 L Join Date: Mar 2011
Up!
Is any one who made this work? I have one conector but orginal camera has diferent plug... |
#28 | |
The wires on the connector are red (power), white (video ground), black (video output), and brown (power ground).
#29 |
![]() ![]() ![]() Drives: 2010 Toyota Yaris Join Date: Nov 2012
The only camera connections I've seen are an RCA female from the camera and a power wire. You connect the power wire to the reverse lights in the back of the car.
You run a supplied cable to the front of the inside of the car. Either buy a review mirror monitor or a dash mount. Each take 12 volts. |
#30 |
I change my Yaris 2012 HB radio to the Toyota Touch receiver.
I have oem Yaris rear camera but the problem is wiring harness. My version of Yaris doesn't have the wirings for rear camera. CTScott send me a diagram for audio in French made Yaris. I understand that the wires go to connector F117 (F117 connect to the left top plug of receiver). Can I take the power from reverse light and connect only video power and ground to receiver? What mean CA+, CB+ on the diagram? |
#31 |
You could power it separate of the radio, but the CA+ to CB+ is the positive power output to the camera by the radio, where it only powers the camera when it needs to.
#32 |
So +12V for camera is pin 7, ground pin 15. Right?
Where I can buy the F117 connector? I have no 16 pin connector in my radio wiring harness. Edit: I take reverse gear and check 7 pin and no power... Last edited by william7; 08-10-2013 at 08:22 AM. |
#33 |
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
I have a 2012 Canadian Yaris Le. Was wondering JayGee did the Crown camera fit ?
I was looking into this one http://www.ebay.com/itm/Car-Reverse-...0cd598&vxp=mtr Also, our 2012 models didn't come with any navigation option so I am thinking of wiring it up to those rearview mirror/screen built in ones like this one http://www.ebay.com/itm/Auto-dim-mir...3f0fc5&vxp=mtr Let me know what you guys think. Thanks |
#34 | |
Will try going for this one http://www.ebay.com/itm/Car-Reverse-...0cd598&vxp=mtr Thanks |
#35 |
![]() Drives: 2014 Yaris Icon + 1.4D4D Join Date: Mar 2010
Try here, may be of use: http://www.toyota-tech.eu/aimuploads..._003_187_0.pdf
#36 | |
So I don't think the connector plug will work :( |
| Temp guage and compass in Rear view mirror | Chaad32 | Cosmetic Modifications (Exterior/Interior) | 10 | 10-30-2020 07:47 PM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
