Old 08-23-2013, 09:21 PM   #1
mf4361
Drives: Yaris Sedan
A question about oil change?
This might be a stupid question...
I am about to do oil change to my 07 Sedan. I have just less than 1 liter of unused Mobil 1 Synth oil from the last change in May. Is it ok to use it, together with another (newly bought) jug of exactly the same kind?
Thanks!!
mf4361 is offline   Reply With Quote
Old 08-23-2013, 09:28 PM   #2
bronsin
bronsin's Avatar
Sure!
In general all oils are made to be compatible with each other. You could mix synth with conventional, 5-30 with 10-40, amd so on.
What you want to do is consult your owners manual and follow its instructions when you have a question.
If you dont find the answers, then consult us here!
Old 08-23-2013, 10:38 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
The only way you really need to be concerned is if it stays in cold weather like winter freezing weather. Pretty much all oil providers tell you to store motor oil above a certain temp to maintain the molecular structure it is supposed to.
Old 08-23-2013, 10:41 PM   #4
jcboy
Drives: Sedan 07
^^this. plus ensuring the cap was sealed correctly prior to storage. moisture wouldn't mix with the oil, but the container condensation (inside) can be swept along while you're pouring it.
Old 08-23-2013, 11:00 PM   #5
mf4361
Drives: Yaris Sedan
Thanks so much for the quick response!
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Jacking up car for oil change question caineroad General Yaris / Vitz Discussion 21 06-05-2012 06:59 AM
$86.44 for oil change? I feel screwed behour General Yaris / Vitz Discussion 98 01-04-2010 07:10 PM
Oil Change Issue. Twistoffate0817 General Yaris / Vitz Discussion 56 05-05-2009 10:27 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
