Old 12-10-2012, 08:19 AM   #1
Kennymen
Drives: Yaris 1.0 VVTi 2004
Adding steering wheel audio control to MK1 P2
I own a Yaris MK1 P2 with the Matsushita CD stereo.
I would like to have the steering wheel controls too, so I was thinking to get a second hand original switch and build it in.
Do I need the whole wiring from steering wheel to unit (as far as I know the controls are connected to the Multi-display assy) or just the controls?
Or is it even not possible to add controls?
I was thinking to get something like this: Yaris second hand switch
BTW: I'm also thinking to build in a CD-changer MP3 extension to play music from SD/USB. Does anyone own something similar?
USB/SD/AUX for Yaris 1999-2005
Thanks, Kenny
Kennymen is offline   Reply With Quote
Old 12-10-2012, 04:33 PM   #2
There are two different part numbers for the spiral cable (the wiring device that allows the steering wheel to turn without breaking the wires for the airbag, horn, and radio controls). 84306-0D012 is the part number for the standard one and 84306-0D050 is the part number for the one which supports the steering wheel controls. So, if yours did not come with the controls then it probably has the spiral cable which doesn't have the extra wires for the controls.
Old 12-12-2012, 02:22 AM   #3
Kennymen
First, thanks you for your reply.
So, I'll probably have to change the spiral cable to. Hmmm... let's say I'll wait for a right chance to get one and then decide.
Do you maybe know how complex is it to swap this cable (time, special tools, special knowledge)?
What about the CD-changer extension? Anyone?
Old 12-12-2012, 09:19 AM   #4
Changing the spiral cable is not all that bad. The only tools required are a torx T30 screwdriver to remove the airbag and a 19mm socket to remove the steering wheel.
Here is a video that I put together that shows the process. It is on a 2nd gen Yaris, but the first gen is about the same:
http://www.youtube.com/watch?v=LgWSzVeILhc
Old 12-13-2012, 06:33 AM   #5
Kennymen
Ok, thank you for the info.
Do you maybe know if the wires from the spiral cable to the Multi-display assy are supporting controls or do I have to get those too?
Old 12-13-2012, 08:54 AM   #6
I suspect that that wiring is not present. You can remove the steering column cover to get a look at the spiral cable connector.
Old 08-31-2013, 09:07 PM   #7
Ash187
Drives: Toyota Yaris 1.3 Manual
Bumping an old thread but did you get anywhere on this? I am wanting to install the steering controls on my GFs mk1 yaris too but can't find any decent info on it
Ash187 is offline   Reply With Quote
DIY Cruise Control for 2012 Yaris - Good News! CTScott Third Gen Yaris General Discussion 305 10-27-2025 02:52 PM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
US '09 5-Door LB: How do you remove the steering wheel? IsLNdbOi DIY / Maintenance / Service 5 06-30-2010 12:50 AM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 06:52 PM
