Old 07-21-2013, 09:18 PM   #19
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by scioncrew View Post
I sad to hear about your motor but i think the motor has had a good life. good luck on your next build.
Thanks, yea the motor did have a good life. Im not too upset because I feel I got a lot out of it. Even though It has been a week, I do miss driving that car.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 07-21-2013, 09:42 PM   #20
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
When are you going to tear into it to see what needs to be fixed?
Old 08-24-2013, 05:58 PM   #21
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I have time finally, and plan to pull the head tomorrow here at home. Ill take a few pics
Ptuning.com
Old 08-24-2013, 10:16 PM   #22
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
finally i was starting to think you forgot about us. :P
Old 08-25-2013, 01:19 AM   #23
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
very curious!
Old 08-25-2013, 11:18 AM   #24
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
my focus was in another place for a while, so my xA was on the backburner. I attended a world cup downhill race a couple weeks ago, and had a good spill during a practice run. Im back to normal now after a concussion, which took a while to shake. Unrelated, but here is the video... I was on the outside of another rider and ran out of road, sherrif found me unconsciousness face down in the water. http://youtu.be/Udk_TqRY4rc
File Type: jpg 537189_10200367607014999_1898370373_n.jpg (48.4 KB, 178 views)
Ptuning.com
Old 08-25-2013, 12:55 PM   #25
wow.
Old 08-25-2013, 10:08 PM   #26
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Bent cylinder 3 intake valve. Cly 4 damage is from a detonated spark plug ( 6 months ago or so). I reported about that on here in another thread ( Ill bump it). The valve definately indented an impression on the piston, but It isnt structural damage. The damage in cylinder 4 from the spark plug ceramic floating around is rather bad. The wall is really scored, the piston top is knicked up and blasted.
My plan for now is to put another head on, with stiffer valve springs, and higher lift cams. I want to then find the structural limit of this motor (40psi?) . Instead of starting over with a fresh bottom end now and risk damaging it (because im greedy), Id rather not waste a whole new build on experimentation.
File Type: jpg 1239566_10102148481917492_841663457_n.jpg (68.7 KB, 165 views)
File Type: jpg 1176204_10102148462631142_413607918_n.jpg (82.5 KB, 164 views)
Ptuning.com
Old 08-26-2013, 02:12 AM   #27
Yes!
Old 08-26-2013, 12:46 PM   #28
justjesus
justjesus's Avatar
Drives: 2008 Liftback
face down in the water! DAAAAMN
glad you made it out (and 3rd place! wow)
Old 08-28-2013, 05:53 PM   #29
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
replacement head, ready to go on this weekend. Supertech valve springs installed, head decked and cleaned.
File Type: jpg 1236412_10201571802549641_2137229214_n.jpg (68.9 KB, 141 views)
Ptuning.com
Old 08-28-2013, 11:13 PM   #30
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
sooo shiny
-Derrick-
Old 08-30-2013, 11:01 AM   #31
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Holy...crud! Your lucky!! Glad everything appears ok...
JustDidIt is offline   Reply With Quote
Old 09-01-2013, 10:22 PM   #32
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
xA is together and running !
Ptuning.com
Old 09-02-2013, 11:38 AM   #33
Golddeenoh
Golddeenoh's Avatar
pictures/video or it didn't happen. :P
Old 09-02-2013, 12:24 PM   #34
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
I drove it around last night, the valve springs alone have made a noticable improvement in power above 6600rpm. With the oem springs the car was probably experiencing valve float robbing the power. The dyno will tell the story. I was going to do more work (cams, maybe valves), but I need my car squared away and dialed in for an event coming up. However, expect a good gain because this thing is going to be tuned for some crazy boost levels .
Ptuning.com
Old 09-02-2013, 09:04 PM   #35
Golddeenoh
Golddeenoh's Avatar
you excite us too much!!
Old 09-03-2013, 08:51 PM   #36
fnkngrv
fnkngrv's Avatar
I bet once next summer roles around you and I would have a bunch of fun!
Finally!!! SkittlePig Australia 11 07-05-2010 07:49 PM
FINALLY!! nickhjort DIY / Maintenance / Service 18 01-16-2009 11:09 PM
Yay finally got my YRX (photos) Spikeles Australia 15 11-12-2008 03:16 AM
I'm FINALLY getting my Yaris! sherryberry New YARIS Purchase Forum 22 07-09-2007 12:08 PM
Finally! KittenRD New YARIS Purchase Forum 6 01-01-2007 09:16 PM
