Old 11-07-2013, 05:18 PM   #1
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
Intake selection
Hello guys,
Back again :).
I'm buying an air intake tomorrow and after searching and speaking with a couple of members I decided to gets the Injen CAI which is on sale, but I got a little scared seeing the installation instructions and the pain of having to remove the bumper to reach the filter.
I was thinking about getting the aFe intake but it says, "Yaris 1.5L" and I "think" my yaris is a 1.3 litter. Not sure (3 door, manual tran, 2010, everything is manual inside )
Here are the links for more reference.
http://shop.microimageonline.com/aFe...L-51-11302.htm
http://shop.microimageonline.com/Inj...ris-SP2024.htm
Thanks for any input.
vaironl is offline   Reply With Quote
Old 11-07-2013, 05:19 PM   #2
All US Yaris have 1.5L 1NZ-FE engines, so either would be fine.
Old 11-07-2013, 05:23 PM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I have the Afe and I love it
Old 11-07-2013, 05:25 PM   #4
vaironl
vaironl's Avatar
Good to know this, now I have no worries.
Do you have an opinion on the intakes? If I'm not incorrect the injen will be harder to install but it will also have a slightly better gain?
Old 11-07-2013, 05:30 PM   #5
TOLMACH
Drives: soarer
I have a trd one which seems to be the best one in terms of build quality - nicely polished stainless steel .. but would go with AFE or K&N this time becasue of easier access
Old 11-07-2013, 06:16 PM   #6
I think they are all pretty similar (or negligibly different) as far as gains go, so it is really all about which one you like the looks of best.
Old 11-08-2013, 12:13 AM   #7
xb visitor
Drives: scion xb
I don't have a Yaris, But I do have the same motor in my XB. I have had a INJEN CAI in my car since it was a few weeks old in 2003 a decade ago...WOW time flies Anyways I have the version that snorkels all the way down behind the running light cutout.
As far as any perceivable performance gain...?? I don't think its possible to even notice a improvement, In theory I'm sure it does..but its not anything you will notice. What it does deliver is a cool intake sucking noise..if you like that. I kinda do. At least it makes the sound of performance
In addition its a good looking well built unit with a resueable washable filter that I do oil IMO its important I re oil it every 3 months or so.
I lost the lil sticker I was supposed to get with it for the Calif smog laws..so I have to take it off every two years and re install the stock filter setup...only takes a 1/2 hour. So Ive donbe this close to 6-7 times back to the stock filter and Truthfully...I feel nor see no power difference from one to the other after 130,000. Id like to think I'm qualified to give a accurate impression. IMO its a wash. If there is a difference its flat out down hill on the freeway, when the speedo reads a optomistic 121 mph
FYI I also have a INJEN " fireball" axle back kit installed at the same time...same thing no difference in perceivable power, actually I do belive I lost a little off the line grunt..it does sound good..but the problem is when you get on it..everyone know what your doing so they floor it ...and them the inevitable humiliation of them blowing your doors off, be it either a Prius, mini van or neon...lol
Unfortunately there is a reason these cars are about the same speed as a SMART CAR...at least we have fun in them regardless
I had a 03 Matrix XRS with the 2zz 6 spd motor, I had Toyota install a TRD CAI...on that engine it made a "bold" difference you could feel, Unlike our motors, the XRS motor had the variable valve intake cam that could actually ingest ALOT of air and make power and rev past 7000 rpm!!!, something the Yaris/Scion motor cant really exploit "at least in stock form"
Obviouslly if you have engine work, cams and or supercharger or turbo..then the rules change and it would be able to utilize the added air and add substantial "noticeable" power gains.
I Don't think there is a traceable "performance" difference between TRD, INJEN or any E-Bay filter in any application, other than the theoretical design of a short ram vs, Long ram and colder air being injested. One last thing.....Obviouslly...use caution when approaching deep water..kiss of death.
I think you will be happy, just don't have large expectations.
xb visitor is offline   Reply With Quote
Old 11-08-2013, 07:22 AM   #8
1.5
Form>Function
1.5's Avatar
on our small little motors, any intake will net you pretty much the same gains. Maybe 2-3whp overall for any intake is about all you could expect. If you dont want the extra work just get one of the top mount short rams like the AFE or K&N
Old 11-08-2013, 07:31 AM   #9
vaironl
vaironl's Avatar
Users were satisfied with both, so I guess either choice would've been fine. But, since I read about cel problems with the aFe I got the injen. I also might get some help from someone who has a bit more experience to install it.
Old 11-08-2013, 07:54 AM   #10
1.5
Form>Function
1.5's Avatar
Yea everyone seems to have those problems but I have never had one issue and never threw a code. Try reading through the DIY and attempt it yourself, its a great first mod to learn and its a great way to get a little hands on mechanic experience. Honestly it looks a lot harder than it really is.
Youll enjoy the injen no doubt, and dont forget to post pics once done!
Old 11-08-2013, 05:08 PM   #11
catliektheif
catliektheif's Avatar
Drives: 2010 5 Door
This.
But that doesnt mean i wont watch and help :)
my afe threw cels but it took some fiddling with the screws on the MAF to get it right.. im CEL free now for a while now actually
lol okay
Old 11-08-2013, 05:28 PM   #12
You might want to get tested once a year to make sure.
Old 11-08-2013, 06:15 PM   #13
vaironl
vaironl's Avatar
Originally Posted by catliektheif View Post
This.
Good to have some help around, plus I only have a 40 piece socket set and a couple of screwdrivers .
Therefore, the help is greatly appreciated
Old 11-08-2013, 11:57 PM   #14
mario98c
mario98c's Avatar
Injen>Afe
Old 11-09-2013, 02:14 AM   #15
catliektheif
Drives: 2010 5 Door
no need, garm! Stomping on your instrument cluster rids all warning lights!
lol okay
Old 11-09-2013, 08:45 AM   #16
1.5
Form>Function
1.5's Avatar
hahahahahaha
Old 11-13-2013, 09:31 PM   #17
vaironl
vaironl's Avatar
Adding to this is a bypass valve necessary with this intake?
Old 11-13-2013, 11:11 PM   #18
^ Not at all.
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 05:34 AM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
The great intake debate! fmicle General Yaris / Vitz Discussion 74 10-06-2009 11:37 PM
Air selection intake broken? David81 General Yaris / Vitz Discussion 16 06-29-2006 02:51 PM
