Old 11-21-2013, 11:59 AM   #1
brg88tx
Drives: 07 Yaris Sedan, Auto
thinking of buying some used rims
they are 15X7, offset +38, 4X100 bolt pattern. the seller says the hub is 56mm with the insert ring in place and 67mm without it. (i'm clueless about this)
Will these fit the yaris ok?
brg88tx is offline   Reply With Quote
Old 11-21-2013, 12:10 PM   #2
Those would be fine. +38 is about the limit of offset to avoid rubbing. 56mm hub centric rings are OK, as 54.1mm ones (which is the correct size for the Yaris) are very difficult to find.
Old 11-21-2013, 08:06 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Hub centric rings don't really matter since we use tapered lug nuts. I wouldn't go over 205/50R15 tires if you're on stock suspension, 195/55 if you're lowered. Source: fender rub on hard corners with 15x7, 205/50R15 and MI springs. Putting in the -1.5° camber/crash bolts resolved the rubbing but caused significant inside edge wear on the tires.
Also, take some time to look at the "official tires thread" to get an idea of sizes that can work, or go to rimsntires.com and check the size comparison tool. Lots of good info to be found on that site.
Old 11-21-2013, 08:46 PM   #4
d3310n
Drives: black titty
ok im lowered and my car is in the shop at the moment but i have been slacking on fixing my rubbing issue. im on r17/40/205. is the rubbing on the inside or outside? basically im asking if wheel spacers would fix this. also a side note, why are they called crash bolts?
d3310n is offline   Reply With Quote
Old 11-22-2013, 06:06 AM   #5
CrankyOldMan
I suppose I should clarify: my racing tires are BFG Rivals (205/50R15 on 15x7) and under HARD cornering I was getting a tiny amount of fender rub on the outside shoulder. There is also some frame rub in full lock turns, but those are only ever at parking lot speeds. My street tires are Direzza DZ101s (205/50R15 on 15x5.5) and I've never had any rubbing issues. I can't say for certain if it's the wheels or the tires that are the cause, but the race tires are almost an inch wider at the tread. I would avoid wheel spacers unless you confirm that you have the fender clearance for them and you're hitting either the suspension or the frame.
As for crash bolts,
Old 11-25-2013, 09:22 AM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
I can get the rings in either 67.1, 72.6, 73 or 74mm to 54.1. They are 2$ each + ship if you want to stock up.
Thinking about painting my rims Qmobile Cosmetic Modifications (Exterior/Interior) 20 04-20-2011 06:24 PM
Thinking about buying a 2006 Yaris Liftback kes New YARIS Purchase Forum 4 07-15-2010 07:34 PM
Thinking about buying a 07 yaris sedan brg88tx New YARIS Purchase Forum 14 06-28-2010 11:57 AM
help! im buying rims this saturday... marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 04-08-2009 12:14 PM
thinking about buying the sedan. is it worth the extra money for the s(optB) version? friedbbq General Yaris / Vitz Discussion 14 05-20-2006 12:53 PM
