Old 11-26-2013, 12:26 PM   #19
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
Rota Grid-V Gunmetal, 15x7 ET20 rondom... with 15mm spacers in the back :)
Also have red closed lugnuts!
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 11-26-2013, 12:27 PM   #20
G-Ammo
G-Ammo's Avatar
oh yeah! garm! check ur PB/Email from microimage...!
Speedbumps suck...!
Old 11-26-2013, 04:20 PM   #21
09cptn
Drives: 2010 Yaris Sedan
I love my Konig LAce with the black lip and machined face. My husband didn't like the crown logo, so I sanded it flat and got custom decals made for the center caps that say TOYOTA in green. I'll try to snag a pic soon.
The Yaris: 2010 Yaris base model. 50% tint up front and 35% in the rear, Konig Lace wheels with homemade Toyota center caps on Yoko S.drives, Curt hitch.
Offroad: 2004 Jeep Wrangler lifted on 33's
09cptn is offline   Reply With Quote
Old 11-26-2013, 06:01 PM   #22
d3310n
Drives: black titty
500 budget, still stuck on these wheels http://www.ebay.com/itm/15-White-Kud...73dc73&vxp=mtr
fixed
d3310n is offline   Reply With Quote
Old 11-26-2013, 06:08 PM   #23
^ can't see them. All I can see is a truck sitting on silver bands.
Old 11-26-2013, 06:11 PM   #24
d3310n
Drives: black titty
whoops lol wrong link http://www.ebay.com/itm/15-White-Kud...73dc73&vxp=mtr
Old 11-26-2013, 06:17 PM   #25
Have you looked through the Official Black Thread?
http://www.yarisworld.com/forums/showthread.php?t=27
If not, start at the last page and work backwards. Less deleted photos that way. There are actually a couple Yari pictured sporting the Rotas.
Old 11-26-2013, 06:29 PM   #26
d3310n
Drives: black titty
thanks very useful thread. giving me some good ideas.
gammo, in your yaris stanced thread how are you lowered in the first pic? im trying to figure out if 15x7s with 175/55r15 will look ok on my micro image springs or im im going to have super wheel gap. i dont want to be super flush since i like my handling but i want the stance to be subtle. mild stretch. decent offset. mild camber.
Old 11-26-2013, 06:32 PM   #27
175s would not be a 'mild stretch' on 15x7s. Better off with 185s.
Old 11-26-2013, 06:34 PM   #28
d3310n
Drives: black titty
note taken. kept in mind that the series is 55
Old 11-26-2013, 06:58 PM   #29
Here are some points that you may or may not be aware of, especially since you seem to be leaning toward a +20 offset:
- the front track is wider than the rear. Since the fronts will poke a little bit, you need to use spacers in the rear to balance out the look
- for some reason, on these cars, the rear axle beam sits to the right of center by about 10mm. To keep things even, you need to space out the left wheel 10mm more than the right. I had been running a setup with an effective offset of +32 and rubbed like a bitch on rear right. Removed a 10mm spacer from rear right and all was equal.
Old 11-26-2013, 07:49 PM   #30
G-Ammo
G-Ammo's Avatar
In the first pic I was lowered on Eibach Pro Kit (25mm)... If you go with 175 on 15x7 you'll get quite some wheelgap... Just as WeeYari says, go with 15x7 with 185 tires just like mine... you can get a nice stance and a nice filled up too because of the 'not so stretched' tire.
If you don't really want to lower it that much, I suggest you go with 16x7 and 185 tires... I think that'll suites you best in my opinion.
Speedbumps suck...!
Old 11-26-2013, 07:52 PM   #31
d3310n
Drives: black titty
yeah thats what im thinkin. i really do want to make 15s work though, the lightness and cheaper tires is so appealing, i just dont think im quite low enough to pull it off :/
Old 11-26-2013, 07:52 PM   #32
d3310n
Drives: black titty
could i cut my springs say 1/8th coil each to get a bit lower? or is that a stupid idea
Old 11-26-2013, 07:59 PM   #33
d3310n
Drives: black titty
well 25mm is about an inch and my springs lowerer me 1.7. considering that you have a 45 seies tire and id do a 55, also with me doing a milder 185 stretch, shouldnt my gap be considerably less than yours was? i dont want to me super flush like i said anyway. im just trying to figure out what it would look like.
Old 11-26-2013, 08:00 PM   #34
G-Ammo
G-Ammo's Avatar
dont EVER cut your springs... if you really wanna get lower and get good handling... take coilovers. I have BC racing coilovers and they're awesome... even on stiffest setting they're still quite comfortable. And indeed... 15'' tires are cheap :) I'm quite lucky with that because I like riding slammed... Or you need to get a fatter tire... like 185/50 or 185/55, but it kills the look / show of your car in my opinion.
Speedbumps suck...!
Old 11-26-2013, 08:02 PM   #35
G-Ammo
G-Ammo's Avatar
yes it'll be less wheelgap... but still quite noticable ;)
Speedbumps suck...!
Old 11-26-2013, 08:08 PM   #36
d3310n
Drives: black titty
ok ok. not too worried about the "show" always function over form, most of these mods are coming from performance gains actually, ill have a lower final drive ratio, some camber helps cornering, lower unsprung weight, and wider track. i figured i could do this all in a way thatll give me a mild stance look, which will be nice. also, im going to school to be an auto tech, so you can imagine how my buds would be laughing at me if i rolled up in a "herrfrush" ride lol
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
