![]() Drives: 2007 Toyota Yaris Join Date: Dec 2013
Replaced dead battery, car won't start
I'm getting my Yaris towed in the morning but I'm hoping someone may have an idea on my issue. I left my dome light on overnight, and in the morning the car was dead. The first jumped started it after a few tries but once I turned the car off, it wouldn't start again. The second jump caused the horn to beep and then nothing. We replaced the battery and still nothing. Not wven making a trying to turn over noise. The only light that works is the door open light and the door open beep. I'm thinking ignition switch, starter or alternator. Anyone experienced this and have any input? Thanks!
#2 | |
No alarm.
And, no aftermarket keyless entry or remote starter?
If not, then definitely check the fuses. For the horn to honk on its own, the most likely reason would be having the battery cables reversed.
I do have an aftermarket keyless entry.
Sorry remote start aftermarket. Keyless entey came with the car
OK. So the remote starter is probably what it honking the horn. I would still check the fusible links, but also check the remote starter to make sure it is not hung. You could try disconnecting the battery for a minute to reset it, or if you have the manual for it, see if it has a diagnostic mode.
Thanks!
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
Yep, check fuses. When I see this, I sometimes see where someone hooks up the jump cables Mcbackwards, and pop, fuse out. Boink, no start.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 02:15 AM |
| Custom Lftback - Photo-Scavenger Hunt | custom Lftback | Photo-Video-Media Gallery | 2 | 03-02-2009 12:12 AM |
| Darb - Photo Scavenger Hunt | Darb | Photo-Video-Media Gallery | 3 | 03-01-2009 10:02 PM |
| Black Yaris - Photo-Scavenger Hunt | Black Yaris | Photo-Video-Media Gallery | 2 | 03-01-2009 05:13 PM |
