Yaris beginner
Hi all!
First of all, many thanks in advance for any help you might provide!! I've order some wheel spacers (H&R's, 10 mm for the front wheels and 15 mm for the rear wheels). I've been doing a lot of research and I'm not afraid of the rear wheels (remove wheel, remove brake drum cover, bang the old studs out, sit the new studs in, reinstall wheel). But I'm a little afraid of the front wheels! Is it possible that I will have to remove the disc brake thingy? Is it possible to get it out of the way without having to drain brake fluid or any of that potentially unsafe for noobs like me procedures? Any light you might shed for me on this will be greatly appreciated :) Oh, almost forgot, I've got a 2011 5 door european hatchback (model XP9F). Thanks, Bruno |
You don't have to disassemble anything in the front. There is a spot in the knuckle where you are able to slip the studs in and out freely. I have a spare hub lying around. I'll see if I can get you a pic.
Here is a pic of the back side of the hub. You can see the half moon shaped recess in the dust shield. If you do find you need to remove the calipers, all you have to do is remove the 19mm bolt at the top and bottom of the caliper and slide it off of the disc. You can just let it dangle on the brake line while you address the studs.
If your car has ABS, be very careful when pounding out the rear studs. Having them pressed out would be safer to avoid damaging the rear ABS sensors.
For the fronts the brake caliper can be left connected to its feed hose. Just use something to hang it from the spring to prevent it from hanging against the hose.
Yaris beginner
You guys are life saviors...
I couldn't be more confident about installing them myself now... And, what a coincidence, I just received them hahaha!! (Had them delivered to work, as there's usually no one at home). Just need to go to the shop and get those washers and nuts to sit them in and I'll be installing them asap. I'll also be posting pics so that you can see the result :) Cheers!! |
#7 | |
Yaris beginner
"Hanging against the hose"... Sorry my mother tongue is not English and I'm not sure I know what this means... does this mean that if I do need to take it off I should somehow "attach it" to the suspension spring? So that all it's weight is not on the hose? If I do need to take it off I'll either have someone hold it while I take the studs out or I'll put maybe a box underneath so that the hose is not under a lot of stress, if that's what you're saying! Thanks again! |
#8 | |
He meant pressing them with a tool.
Just pile up something under the caliper to support it. Books, wood, whatever.
My fear for you is actually the rear studs. I have Ichiba 10mm and the studs they provided me with were way too long. Unless I was a completely brain dead blind idiot at the time, they was no way in hell there was enough room in the drum to slip those in. Had to go to an auto parts store and source out studs short enough to slip in, yet long enough to accommodate for the spacer.
Yaris beginner
Ok guys thanks!
WeeYari, I'll let you know
#11 | |
Bought used, never installed product. I've heard of other instances where the Ichiba supplied studs were too long. I think the packaged ones were actually 20mm (maybe 15) longer than OE. Don't have my OEs on hand to compare right now. They were HUGE!
Specifics on Ichiba supplied stud: - threaded portion 48mm - knurled portion 9mm - head portion 5mm - total length 62mm
toyota
not that hard although power tool, flat screw driver and a hammer will come in handy...
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
Nope. OE stud length + 10mm is sufficient for alloys. The issue with 62mm is there is not enough space between the back of the hub and the brake mechanisms to angle the stub up and into the hub hole. OE + 10mm just makes it in. I suppose they could go in if you remove a brake pad. Then again, even if you got those suckers in, they may be too long for closed lug nuts.
#15 | |
Yaris beginner
A little picture of them, got them yesterday as I told you :)
So the rear can really be tricky heh? I guess I'll find out soon! I might postpone this to spring time though... as it is friggin' cold around here now :D Cheers |
OE vs Ichiba
OE stud total length is 45mm, so the ones shipped with 10mm Ichiba spacers are 17mm longer. Hopefully they have rectified this.
#18 | |
You won't have enough stud length in the rears to do that though with the 15mm.
| Tags |
| wheel spacers diy |
| installing Penguin Garage rear hub spacers! | Tamago | DIY / Maintenance / Service | 101 | 05-21-2011 12:29 PM |
| Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed | RedVitz | Photo-Video-Media Gallery | 18 | 10-09-2010 03:36 PM |
| Installed 10mm PG spacers on a 15x7 +25 wheel | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-27-2009 07:10 PM |
| Steering Wheel Spacers? | BassAssassin | Cosmetic Modifications (Exterior/Interior) | 0 | 08-12-2009 12:52 PM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
